01-19-2014, 04:09 PM | #1 |
Rep 194
25mm spacer?
Thought to post here also:
I got the KW V3 and I am in the middle of the installation. Got the front coilovers installed but when I tried to mount the wheels the wheel/tire hits the suspension so obvious that I can't even make the wheel come near the hub. Measured the space and its about 25mm between wheel and hub if I leave 10mm between inner wheel/tire to suspension. Should I really get a 25mm spacer? or 20mm? or what? How about the rears? will I need? Note my wheel/tire setup: Apex Arc-8 size/offset: F 18 x 9 ET42 R 18 x 10 ET25 Tire: Front: 245-40-R18 Rear: 275-35-R18 Original thread: http://www.zpost.com/forums/showthread.php?t=894677 |
01-20-2014, 09:01 AM | #3 |
#dubspec
6317
Rep 5,200
25 up front will rub like crazy and stick out
