04-20-2011, 11:37 AM | #1 |
Rep 221
Z4M crossover pipe material
I'm planning some mods to the Z4 M crossover pipe. Want to take out the resonator and replace with some better flowing pipe. So I need to know what material to get the tubing in.
Anyone know what material the Z4 M crossover pipe is made of? Aluminum ? Stainless 304 ? Stainless 409 ? All I know for sure is that it's not carbon steel... -M
2011 E92 M3 mods: Alex tune, mod'd X-pipe, MPEv2, MS intake stage 2, ESS power pulley, Monoball bearings, SSFBs, PFv3 rotors, MFactory DSv3, RE SSK, Voltphreaks Li batt.
For sale: E92M3: BW Race muffler, front thrust arms, stock muffler, 19" Vorsteiner VFF103 rims Z4MC: KW V3 coilovers (rears) |
04-20-2011, 11:55 AM | #3 |
M52, M62TU, S50US, S54, S65
75
Rep 569
My SS X-Pipe is made out of Stainless 304.
1995 E36 M3 USA / 2002 E46 M3 SMG / 2008 E90 M3 6MT 1996 E36 328i Touring 5MT / 1998 E36 323Ti M Sport 5MT 2002 E39 540i Protection |
04-20-2011, 12:25 PM | #4 |
Rep 11,667
Rouge Eng. has an X-pipe that replaces the OE section
04-23-2011, 01:15 PM | #5 |
Rep 221
Thanks for your replies.
If it's stainless, how do I tell the difference whether it 304 and 409? Btw, I'm doing this mod predominantly because I like welding and because I've had success in the past putting an entire exhaust system together. Obviously my goal is to improve sound and flow at the same time. I have not cut the resonator out yet. But I suspect it does in fact restrict flow as follows. If you look closely at the input pipes to the resonator, you will see that the pipes have been crimped, or crushed, on the outer sides. It looks like a 3" x 1.5" long 1/2" recessed indentation. My guess is that this was done to cause turbulence of the gases in the resonator to make the resonator more effective. Turbulence, however, is not good for flow. By removing this turbulence, the flow should improve. Secondly, by removing the resonator, the exhaust will become a little louder and probably, flow is improved a tiny bit more because it looks, from the outside, that the bend inside the resonator is tight. Aftermarket crossover pipes are 2 1/4" all the way to the muffler. This, I believe, is too big for optimal flow at this portion of the exhaust. I think the optimal design is somewhere in the middle between the stock and the aftermarket crossover pipes. I feel that 2" piping, after the X-pipe section, is optimal for HP up to 400HP and that is effectively what the stock crossover pipe size is immediately after the X-pipe section. See, gases are not that hot after the X-pipe section and therefore can benefit from a smaller pipe size to keep them moving fast and thus slightly aid the scavenging effect. After all, the secondary cat section is also made of 2 1/4" pipes, and here gases are much hotter. Thus, pipe size further down should shrink to make for a wholesome integrated exhaust system, and which BMW actually did. Even their mufflers are made of 2" piping. They just don't flow that well. I also plan to wrap the entire crossover pipe in thermal wrap to keep the gases as hot and fast as possible. -M
For sale: E92M3: BW Race muffler, front thrust arms, stock muffler, 19" Vorsteiner VFF103 rims Z4MC: KW V3 coilovers (rears) Last edited by cmichaelo; 04-23-2011 at 04:09 PM.. |
04-23-2011, 04:10 PM | #6 |
Engineer
216
Rep 2,122
Drives: M235I 2015, 335i 2011
It's 409
04-28-2011, 09:56 AM | #8 |
Rep 221
Dio, Thanks. Now I can go get the proper welding wire.
Villa, I had not considered that. Will look into it.
04-28-2011, 10:01 AM | #9 | |
Rep 4,726
04-28-2011, 11:54 AM | #10 |
Rep 221
I hear sighing helps you to relax and vent feelings. I could sure use some of that. Thanks Cha!
04-28-2011, 03:32 PM | #11 |
Rep 1,772
Drives: 2007 Z4M Coupe
Take good care of my X-pipe. Maybe if you get good results I will buy it back from you !
