      05-05-2011, 11:43 PM   #1
VinnieAces
VinnieAces's Avatar
Drives: Imola Red Z4MC
2006 Z4 M Coupe  [8.00]
OBD-II-Code-P0301 - help
The car starting acting extremely strange just before i pulled into my street, prior to this i heard kind of a ringing noise, almost as if metal was vibrating.
Basically the car sounds like a west coast customs chopper right now, misfiring everywhere, gurgles pops u name it,
the throttle is very sketchy,
my ODB II scanner gave me 5 codes, 4 of them being 02 sensors from just installing my headers, the 5th was P0301 which is Misfire Detected in #1 Cylinder
Can anyone tell me what could have caused this? What I can do to fix?
My car is 06 if this is possibly a vanos-related issue that has not had the extended bolts replace the existing ones
recently installed performance mods: AA headers, RPi exhaust, TCKline coils (dunno if this helps but thought i'd add it in)
I was driving my car normally up to this point as well, maybe a few extra down shifts to hear my new exhaust set up
opinions?
///M - Some Mods 'N Stuff
      05-07-2011, 10:51 PM   #2
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Are the O2 sensor codes for primary or secondary O2 sensors? Primary sensor malfunctions can cause a misfire.
Vanos bolts are definitely a possibility. There's a DIY check on here somewhere. IIRC you don't actually look at the bolts themselves; instead, you try to wiggle one of the VANOS gears and check it for play. The DIY is for the valve adjustment.
Obviously don't drive the car.
Edit: What's the build date of your car?
      05-08-2011, 12:24 AM   #3
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
just relocate your sensors .
      05-08-2011, 03:29 AM   #4
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
Check to see if your air intake / filter is properly attached and secured.
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
      05-08-2011, 08:47 AM   #5
Quickid
Drives: 08 Z4MC, 06 X5 4.4i, 99 323i
I was just reading some post on the M3Forum.net with very similar symptoms and P0301 code. I think it was the VANOS solenoid in this guy's case.
... Edit: Here, I found it. Hope that helps narrow it down... http://m3forum.net/m3forum/showthread.php?t=330862
Good luck!!!
      05-08-2011, 08:51 AM   #6
MPOWER78
MPOWER78's Avatar
Guatemala
Drives: 08 /// M
It may just a bad ignition coil #1 with spark plug if one goes bad that is what happens ..
      05-08-2011, 01:28 PM   #7
VinnieAces
VinnieAces's Avatar
Thanks for the help guys, still looking into the problems myself, might just revert everything back to stock and flatbed to bmw
      05-08-2011, 07:49 PM   #8
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
^ Always an option. If the problems persist then you can rule out your install. It's possible the install is simply coincidental and there's no correlation to the problems you're experiencing. In which case if it's under warranty I'd rather have it on their dime (and rightfully so since it would be independent of the mods).
      05-12-2011, 11:32 AM   #9
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
When you install your coils it is possible to not push them in fully causing a misfire. I had that problem on my E46M. Make sure to push them in firmly before locking them in place. That's an easy check so I would definitely try that.
Also make sure you did not cross your 02 sensors. That will make you throw all kinds of codes.
Give us the actual codes that you threw. There is also a fuse in the DME that sometimes gets blown which will throw half a dozen codes and put you in limp mode.
      05-12-2011, 12:46 PM   #10
johanness
Drives: 2008 Z4MC
^^^True. When you cross your O2's, your car will run like shyte. Giving the actual codes will help
      05-12-2011, 01:21 PM   #11
VinnieAces
VinnieAces's Avatar
when you say cross your 02 sensors, do you mean putting them in the wrong spots in the headers? if so i made sure i marked each one where they were spose to go
Car was shipped out to bmw today though, guess i'll let them deal with it, Wooo CPO'd car lol
      05-12-2011, 01:45 PM   #12
Z4-VILLA
Afghanistan
111
yeah my shop crossed the o2's when the did the relocation....they rectified it for free though,......easy miss to make absent proper markings
      05-12-2011, 04:38 PM   #13
Jumbosock
Jumbosock's Avatar
76
Yes I meant keeping the pre and post sensors in their correct banks. People commonly mix them up and throw codes.
      05-16-2011, 04:58 PM   #14
VinnieAces
VinnieAces's Avatar
Update:
BMW called back and said it was the bolts in the VANOS that came loose and fucked everything up,
Warrenty IS covering it however and my car should be fixed sometime this week!
So, to everyone with an 06, GO AND CHANGE THOSE BOLTS ASAP!
      05-16-2011, 06:32 PM   #15
pokeybritches
2006 BMW Z4M  [8.50]
Wow. Another. How many miles?
      05-18-2011, 02:17 AM   #16
Jumbosock
Jumbosock's Avatar
76
Originally Posted by VinnieAces View Post
Update:
Were you hearing any noises prior to this happening?
