      06-16-2017, 04:40 PM   #1
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
What tire size for square setup?
Since our stock Diameter is 25.72 R and 25.97 F, the popular choices are 265/35-18 square.
It's the 265 is 25.3" in diameter but smaller than stock. Shorter side wall, better turn in and more torque.
Has anyone tried 255/40-18? Recommend, against, or? Diameter is 26.03" which is less of a Delta than going 265.
Just got a killer deal on a set to try in those sizes and they might fit better in the front width wise. It'll be my first attempt at 200 tread wear set.
TIA,
FB Group-- > fb.com/groups/z4group
FB Page-- > fb.com/Skyermotorsport
      06-16-2017, 04:59 PM   #2
angelr
I haven't run them but up front the taller profile could cause and issue depending upon wheel offset. 245-255-265 all fit width wise but I've encountered contact with the rear of the front bumper with a 265-40 series over the 35.....plus I like the gearing advantage even if it's small.
      06-17-2017, 12:43 AM   #3
scrammer
scrammer's Avatar
Drives: 2017 M3 Ultimate
square set ... 18 x 8.5 et 35 - 15mm H&R spacer in back and 235.40.18 P-Zero tires all around
Current ///M: 2017 M3 Ultimate
Past ///M Cars: E92 M3 ZCP 'CDN LRP' … E85 Z4M-R ... E92 M3 ZCP Frozen ... E90 M3 ... E46 M3 Cab ... E46 M3 ZCP ... E46 M3
      06-17-2017, 01:10 AM   #4
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Nice wheels and I had a set of BBS RGR in Diamond Black 19s prior and still miss them. What tire and size are you running?
Just realized that you're in Kelowna, might be heading over there during the summer. Give me a shut when you're in Van.
      06-18-2017, 08:14 PM   #5
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
I'm running 255-35-18 on 18x9.5. +35 nonissues with my alignment setup
2007 BSM Z4M Coupe - 18" VOLK TE37 - 18" Apex ARC-8 - GC Track/Street
      06-18-2017, 09:58 PM   #6
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
What suspension setup do you have? Camber spec?
thanks,
      06-20-2017, 04:46 PM   #7
Jackal
Jackal's Avatar
Drives: 2006 Z4MC (Bianca)
I run a 265/35/18 square setup on 9.5" 35ET wheels with a 5mm plate up front and 10mm in the rear. Springs are H&R lowering springs. Some adjustment was needed to ensure no rubbing, but now even when racing autox they don't.
Light a man a fire, you keep him warm for a night. Light a man ON fire,you keep him warm the rest of his life.
      06-20-2017, 04:55 PM   #8
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
This is exactly the answer I'm looking for. Thank you! I have 5mm and 12mm and will try those with my current alignment.
      06-22-2017, 03:00 PM   #9
Jackal
Jackal's Avatar
Before making the swap, be prepared to max out the front camber. I run -3* up front and had it ready to go before putting on the front wheels. I use camber washers to get the extra bit up front.
      06-22-2017, 03:28 PM   #10
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
@Jackal
Do you think I can run that with OE suspension and camber washers? I've already got the pin pulled and Max out at 2.1° in the front I think. I want to go with those tires before I do suspension upgrade and over-hual.
TIA,
      06-22-2017, 03:56 PM   #11
i2ichal2dZ4M
thanks,
-2.8 of front -2.5 rear
      06-22-2017, 04:01 PM   #12
i2ichal2dZ4M
@Jackal
TIA,
You will be okay with pin removed and turners camber washers on oe suspension. I tracked that setup with minimal issues. I also run a 5mm spacer front and 10mm spacer rear
      06-22-2017, 04:06 PM   #13
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
@Jackal
TIA,
Thank you for that info. I'll purchase the Turner camber washers and get an alignment done. Already installed 5mm & 12mm spacer last night, with old 245/275. Once they are out, I'll try 265 all around. Much appreciated.
      09-27-2017, 08:52 PM   #14
mtnbkr
mtnbkr's Avatar
Drives: '06 IB Z4MC
I'm glad the OP was able to find the size for their setup but does anyone have actual experience with 255/40R18 as a square fitment on 9.5" rims? It irritates me if my speedo is under-reporting and while a 40 profile results in the same OD as original I'm unsure if it'll rub with a mild (~1/2") drop. Yes I realize a 35 profile may have slightly better feel and better for torque but it's also worse at handling rougher roads? and greater speedo error!
I like that the 255 tread width (for the MPSS tire) matches the 9.5" rim which is why I'd like to stick with that size.
      10-04-2017, 06:42 PM   #15
jns_e85
jns_e85's Avatar
74
Drives: '05 X3 2.5i, '06 z4M, '17 M2
I got my current daily set from tire rack when they had the Conti DW on clearance, 255/40/18 and 275/35/18 to go on a set of Arc-8 18x9 et42 (12 mm spacer) and 18x10 et 20. When it came to mount them, the 255/40 were WAY too tall and hit the fender liners everywhere (even with -2.7* camber in the front on stock suspension!). Needless to say, had to scrap the 255/40 idea and go to 255/35/18 instead. Fixed the height/rub issue and fit quite nicely.
IMO 255/40 MPSS on the stock 9" rears are stretched AF, so I can only imagine 9.5" would be worse. Why not do a square 265/35 instead?
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
      10-05-2017, 05:42 PM   #16
mtnbkr
mtnbkr's Avatar
Drives: '06 IB Z4MC
Thanks, just the confirmation I needed. I ended up with 255/35 and they look great (not a fan of the stretched look either but these are just right). I tried putting on the 9.5" ET35 rims with stock suspension and it just touches the strut. A 5mm spacer should solve that problem!
      10-15-2017, 05:03 AM   #17
Over it
Mad Man
Drives: car
What was the adjustment you did to fit your tires/wheels? Did you shim the spring perches?
What tire brand/model are you running? I plan on running RE71R or Rival S, I know the actual tire sizes vary from model to model and brand to brand.
How well do the stock dampers handle the H&R springs?
Any pics?
Thanks!
Carl
      10-21-2017, 06:14 AM   #18
markos_z4
instagram : https://www.instagram.com/markos_z4/
markos_z4's Avatar
Netherlands
64
Drives: BMW Z4 Coupe 3.0si 2006
need a square setup
follow me on instagram:www.instagram.com/markos_z4/
