      01-01-2013, 02:51 PM   #1
markZ4MC
Drives: Z4MC
Front bumper drooping/Wheel well Rivets
Ever since I installed wider tires and lowered my MCoupe, I rubbed away the one of the front wheel rivets. Now my front bumper is starting to seperate from the fender.
Any creative ideas how to re-attach? I could replace the rivet, but it will just rub again.
      01-01-2013, 04:23 PM   #2
Beedub
whats your wheel setup / specs?? just for info, wondering if added camber will help??
      01-01-2013, 11:09 PM   #3
mpm3
mpm3's Avatar
Drives: 2007 M coupe
2007 BMW M coupe  [10.00]
2011 BMW M3  [0.00]
in for info, lol has happened to me as well. i tried zip ties but no luck
      01-01-2013, 11:21 PM   #4
dorifto88
Drives: 88 Nissan Pathfinder
Are you all referring to the bumper clip that helps to attach the bumper to the car?
      01-02-2013, 04:58 PM   #5
markZ4MC
Drives: Z4MC
Possibly
They sit on on the inside of the fender and is a plastic black rivet. Its worn away completely and now the bumber is sagging.
My wheels are 19x 8.5et30, 255/35.
      01-02-2013, 05:50 PM   #6
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
Umm, don't those just hold the plastic wheel well to the bumper? The bumper is held up by the screws under the hood and the clips by the headlight. With some support underneath.
      01-02-2013, 05:52 PM   #7
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Pics?
      01-08-2013, 11:44 AM   #8
j03chu
Drives: 08 SG/IR Z4MR | 07 AW/Blk Z4MC
I've had rubbing issues with my front's for years...
I ran a 19 x 8.5 + 32 (e46 m3 offset?) volks te37's + the current HRE's and ran a 255/35/19 tire for both.
My fender self tapping screws have been worn down completely and replaced, and the bumper clip (that self destructs by the way each time you take it off for 50$) popped off twice from the car turning lock to lock or on a bump.
My issue is that some parts of the wheel well simply just rubs once lowered, its not the very top of the arch, but closer to a 40,45 degrees where the tire rubs off the wheel well. Camber/Toe COULD solve this issue, but I'm thinking of going a bit higher.
08 Z4MR | Space gray on Imola red, carbon trim
BC racing coilovers | Titan TS7
07 Z4MC | Alpine white on black, aluminum trim
KWV3 | CCW LM20 | Eventuri | Rogue Engineering short shifter, mounts and exhaust | BMW Motorsports shift knob | mudflaps | stubby antennas
      01-09-2013, 12:36 AM   #9
Jumbosock
Jumbosock's Avatar
76
Btw, the black clip isn't always destroyed if you use a weeder to gain access to those pesky upper front snaps of the black clip. Just stick the weeder in between the fender and the upper part of the clip and twist counter clockwise as you're pulling down on the black clip. Those pesky snaps slip right out.
http://www.amazon.com/gp/aw/d/B00004...r=8-23&pi=SL75
      01-09-2013, 11:15 AM   #10
3002 tii
3002 tii's Avatar
2282
You're doing it wrong if it breaks everytime you pull off the bumper. See this post:
http://www.zpost.com/forums/showpost...&postcount=450
Follow for latest mods
