03-27-2012, 01:48 PM | #23 | |
Bad Lieutenant
232
Rep 3,517
03-30-2012, 02:04 AM | #25 | |||||||||||
IG: limited.slip
332
Rep 1,918
Greg, thank you for the kind words, I much appreciate it!!
I see there are a few questions and concerns so I will try to address them all. Quote:
Those are present on '02 S54s and up. Look at a 2001 M3/Z3M engine and there are just holes! Quote:
As for the half moons, they do not call for RTV. You only need to put a dab of RTV on the seams on either side of the front of the engine where the vanos is bolted. Quote:
Most commonly the valve clearances get looser over time but I do see clearances getting tighter on a regular basis. Quote:
If you guys says so, then there must be! I will admit this is news to me. I see mostly E46 M3s -the Z4M is a rare car- and on those I am pretty positive there is no RTV from the factory. If there is some on the Z4M then it is news to me! Little things change over production years so I wouldn't be surprised. As for the cam bolts I have never seen loctite on them. Quote:
I'm not sure what you mean but the OP's valves were out of the factory spec (range) on the tight side. Ie the gap/lash was too small. 1 size up in shim was required to get back to spec (neither loose or tight). Quote:
I would say you are partially correct Replacing: 100% correct. Inspecting: say 50/50. I inspect the cam bolts by doing a "wiggle test". Car in gear, ebrake off, grab firmly on the cam gear and rock it back and forth. Rotate 180deg, and repeat. (obviously pull car out of gear while rotating). You are looking for play. There shouldn't be any movement of the gear whatsoever other than its own rotational axis. If a bunch of bolts are sheared you'll catch it. Now this method is not 100% fail proof as you most likely won't catch a single bolt that just started shearing. It is however to be noted that the cam bolt failure won't come out of nowhere and bite you in the ass. The car will make some odd noises or rattles. If you're 'lucky' it'll throw a code. My point is that it's noticeable. So replacing the bolts can be done prior to failure if symptoms occur. With that said, I've replaced the bolts in the past on several cars; either at the owners request who wanted them replaced for peace of mind or while replacing the a broken hub/vanos unit. Those who passed the test came out beautiful. The hub tab failure on the other hand is more the silent killer. People drive around on one tab and have no idea. Car behaves and sounds the same. Until the second tab lets go. Quote:
(First bolded part): You need not find it hard to believe. It happens. I've adjusted the valves on over 80 different S54s so I've seen it all. Nothing to worry in this case. (Second bolded part): The valve adjustment calls for a cool engine. If you drive before you do it you will get inaccurate valve clearance measurements (not to mention burn your fingers ) If you are not sure how to determine if a valve needs adjustment I suggest you read on it. Hint: it's done with feeler gauges Quote:
Well it's getting late and I didn't proof read myself but I hope this makes sense! |
03-30-2012, 09:18 AM | #27 |
Bad Lieutenant
232
Rep 3,517
Agree, great post. Kaiv is the valve adjustment master. He is correct on the RTV, I've only done the E46M3 in the 204-2006 time period, and had to clean the rear half moon area of the factory gunk. They may have added the RTV later in production. Can't stress the "doing it yourself" as the best feeling, especially with more precision feeler gauges at hand as what the dealer techs call "within spec" can actually be out, using the gauges they are supplied.
03-30-2012, 12:36 PM | #28 |
Rep 296
Burn...
I was saying if it is under tolerance on an interferance engine he should not of been driving it, then how did it get to you to work on? Not drive it around and then work on it hot. I know it is done with feeler guages as I have done it myself. I was asking the process as I find it hard to believe that the motor would tighten up that bad. Did you go below .18 and check a .17 or anything? Was it a tight .18 wich still fits but made you uncomfortable to leave that close? Is it your preferance to make everything middle ground? Not saying it could not require a smaller shim just asking the specifics that led to that conclusion. The bag o odd sizes would be nice to have as I have about 10 valves that I would want to half step. I did mine where if a .23 would fit easy I put in a larger shim, if .23 did not fit I just replaced the shim that was in it. There were a few larger than .20 but smaller than .23 that would of used a half step nice. P.S. that would be one size down in shim to open the gap to within spec. Smaller number = smaller shim..... |
03-30-2012, 11:38 PM | #29 | |
IG: limited.slip
332
Rep 1,918
Ok... I'm apologize, I'm just not getting you He shouldn't have been driving it? Says who? Being a little on the tight side is not going to kill the motor... And hypothetically, even if he wasn't supposed to drive it, how would he know anyways, before measuring? (that's not really a question I'm just saying). And you say you know how it's done but then you don't know how to tell if a valve is (too) tight? So you can only tell if it's (too) loose? The minimum gap is .18mm on the intake. .28mm on the exhaust. Anything under that is too tight. If .18mm don't fit on the intake /.28 don't fit in the exhaust = too tight. It is indeed my preference to 'make everything middle ground' as you put it. Given that the clearances can both get tighter or looser overtime, I feel being in the middle is a good and safe spot. Of course you can't always get it right in the middle since the whole clearance is .05mm and shims size increments are .04mm. But in the vast majority of cases you adjust the clearances to be comfortably in the middle of the spec. (if it wasn't the case BMW would provide more shim sizes/increments) With that said if because of the circumstances (current gap and shim size on a specific valve), I have to decide between being very close to tight or very close to loose -yet both still within spec- I'd pick loose side for safety. It happens every once in a while. Again you need not find it 'hard to believe'. Nothing abnormal and unusual there. Seen it many times. I also don't get your 'tightened up that bad'. Needing one an upsize or downsize by a single shim size is normal and not 'that bad'. I did see a car in the past that need to skip a size, on two valves. Now THAT was surprising and unusual! |
03-31-2012, 01:22 AM | #30 |
Rep 2,866
Kevin,
Great post! I might just take you up on the offer to do the transmission and diff fluid changes as well |
03-31-2012, 07:44 AM | #31 |
Rep 296
Ok beaten to death and I guess I am not making sense.
If you could flex the feeler guage in at .18 (tight fit) then I would call it in spec and be done. Because, to step to the next size up it would be just outside of spec .19-.23=.04mm or one shim size, .18 fits nice being ideal in my book. but a snug .18 is better than a snug .23 in my book. That depends on if your going for (your defenition, subjective) safe or performance valve adjustment. When I say performance I adjusted my car for min spec and it changed the way the car drives and sounds. Crisper exhaust note and I actually lost a little fuel economy with the increased lift and duration. Ok so a small change on one valves (6 valves increased in shim size, all shims were replaced) but across 24 valves at 7k rpm and it makes a differance... All this I don't know what I am doing, I was trying to ask an educated question but if you are not understanding me then I can't help you. After adjusting valves on bikes and other cars with a solid valve train I have not seen the gap decrease to date. You can think what you will your entitled to your opinion... |
03-31-2012, 09:50 AM | #32 | |
Bad Lieutenant
232
Rep 3,517
03-31-2012, 10:00 AM | #33 |
Rep 296
Thanks!
I am always trying to learn diffrent view points on diffrent things. I do not want to say that the way I do it is better than doing it another way. I was just asking for a preferance on too tight. If you can wiggle the feeler guage in it is a tight fit but it still fits. One thing that might be good is to make a sticky thread with odd shim sizes people would not mid selling so those of us that want a tighter valve train have the ability to do so. Unless you can order individual odd sizes from somewhere? |
03-31-2012, 10:10 AM | #34 | |
Bad Lieutenant
232
Rep 3,517
04-01-2012, 05:19 PM | #35 | |
IG: limited.slip
332
Rep 1,918
Ok, this post I understand. If I was rude previously I apologize but understand that you had me thrown off when on one hand you seemed to not know how to tell if a valve is too tight while on the other claiming you know what you're doing... I feel like I'm wasting time explaining the very basics So again, below the minimum gap is too tight. Over the maximum too loose. Since we're talking about the tight side; if the .18mm doesn't fit at all in the intake side then it's too tight. I agree that tight = performance. Maybe that works well for you since you can keep a close eye on your clearances since that's just you and your own car. But again since valve clearances can both get tighter or looser over time, being so much on the tight end is not the safe choice. I assume I need not educate you of the potential risks of a valve getting too tight. People who have me care for their car(s) and adjust their valves trust me to do a good and safe job, a job that won't potentially run the risk of a valve getting too tight, too soon; and that won't require to keep a closer eye on the valve train (ie shorter valve adj. intevals). This may be redundant but so our readers understand: a valve clearance set towards the middle of the spec has room to evolve safely towards loose or towards tight while remaining within spec (acceptable range) for a longer time. You set your valve on the absolute tight end, it has room to get loose. None to get tight. In any event, the people I help always have tons of great things to say about how the car feels and drives when I'm done with it Have a great weekend (or what's left of it!) |
04-02-2012, 09:19 AM | #36 |
Enrollment Officer
114
Rep 5,014
Maybe this was answered.. sorry if so. But when do you know that your valves need adjusting? My 2008 is at 54000 kms and I do 12 to 18 track days a year since 2009.
04-02-2012, 09:24 AM | #37 |
Rep 784
Drives: 2011.5 E90 M3
I had a slight tick at idle, but that's not typical. When you hit inspection 1 or 2, that's when you need to get the valves adjusted. It's about a 25-30k mile interval. If your car hasn't had it yet, I would say it's due.
04-02-2012, 08:19 PM | #38 |
Rep 134
Hello from montreal. Mine is at 34000 km and, never had this job done. I find that the idle is less smoorh since the last 5-6000 km. Should return my car On the road this week. Will see if the car ad sleep well during winter. Anybody making valve job in quebec ??
