12-16-2011, 07:12 PM | #1 |
Rep 162
oil change question
so...
I've read some stuff on this but I am still sort of un-sure about this. I have a jack and jack stands. I can jack up the front by jacking up there rear and get the stand under the front. How far off the ground do you guys normally get the car? It is high enough for me to shuffle under there on my back but not much else. Does it help to jack up both side of the front? |
12-16-2011, 07:43 PM | #2 |
Rep 924
For oil, I recommend ramps. Then you can fit the jack under the front (using the center lift point) if you need to go higher. You don't even need to get your body under the car if your arms are long enough. I can get at the drain plug just by reaching under from the side of the car.
12-16-2011, 07:45 PM | #3 |
M = Midlife Crisis
65
Rep 2,006
You a Basketball Player?
2006 Z4MC - #LL93158
12-16-2011, 07:57 PM | #4 |
Rep 924
At 6'5", I lack offensive skill but have solid D + rebounding
12-16-2011, 08:27 PM | #5 |
Rep 231
I usually jack up both sides just so it is level side to side but there is really no need.
CDV delete, clutch stop, BMW pedals, Strongstrut bar, CF rad & coil cover, M3 reps, roundel under hood, Intravee II, air bag sticker delete, first aid storage, painted reflectors, headlight washer disable, Skyer CF front lip, Short shift kit, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings, TC Kline DA coilovers, PB big brake kit, Skyer CF rear spoiler and diffuser, oil pressure and water temp guages.
12-16-2011, 09:10 PM | #6 |
Rep 844
Jack up the front drivers side, place a jack stand underneath, crawl under and undo the oil drain plug. Then lower the car, let it drain, jack it back up, put the oil drain plug back in, and lower the car.
12-17-2011, 01:32 PM | #7 |
Rep 162
where do I put the stand if the jack point is used by the jack?
12-17-2011, 01:50 PM | #8 | |
Rep 666
I use the 8000 Rhino Ramp http://www.rhinoramps.com/product.html
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
12-17-2011, 06:17 PM | #9 |
Rolling Republic
14
Rep 236
I have an oil pump that siphons from the top of the engine into a container, because I hate jacking up and what not. For $80 and re-usable, it definitely makes life easier.
12-17-2011, 07:48 PM | #10 |
Rep 1,922
12-18-2011, 07:20 PM | #12 |
Rolling Republic
14
Rep 236
Correct! On my phone at the moment. If someone has a link to the pump could you please direct these fellow Z's!
03-23-2012, 03:16 PM | #14 |
Rep 784
Drives: 2011.5 E90 M3
According to http://www.m3forum.net/m3forum/showthread.php?t=34365 and http://billswebspace.com/Z4MS54OilChange.htm
18 ft-lbs |
03-23-2012, 05:41 PM | #15 |
Rep 162
i am a tard...super easy though I wonder if my vac thing is broken. it took like 10-15 minutes to get all the oil out and the pump handle would raise on its own after pumping.
worked though, so easy..... |
