      08-05-2007, 11:40 AM   #1
mike87
Drives: BMW
DIY Request: Aftermarket Xenon Install
Title says it all. Any help or direction would be appreciated.
      11-24-2007, 11:47 PM   #2
BMW^Z4
BMW^Z4's Avatar
Drives:
I am interested too.
Sterling grey ,108 starspoke, alarm,KW v3 suspension,clear lights,cd/mp3, ipod 20GB, hardtop,manual,wind deflector, aerodynamic package, silver trim,Michelin pilot sport tyres, cruise control etc ...http://www.freewebs.com/knb921/
      11-25-2007, 03:28 AM   #3
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
http://www.zpost.com/forums/showthread.php?t=96215
Good pictures; HID install is pretty straight forward. You can either remove the wheel well upper plate by turning the quarter screws 180 degrees, or remove the whole front bumper. Take out the stock bulbs and insert your HID bulbs, connect the original wiring harness form the car to the ballast then the ballast to the bulbs. Mount the ballast high and dry using screws/tape/zip ties and enjoy.
      01-26-2008, 01:24 PM   #4
ATX750i
ATX750i's Avatar
Drives: 2009 Honda Civic Si
2003 Z4 2.5i  [0.00]
where is a good place to get quality, low cost ballasts? And, is one ballast required for each bulb or one ballast for both bulbs?
      01-26-2008, 03:38 PM   #5
BimmerZealot
Apexcone/DDM Tuning have cheap priced, high quality ballast. You can get a full kit starting at 110$
http://www.ddmlights.com/hidkihidbuhi.html
And one ballast is required per bulb
      01-31-2008, 11:17 AM   #6
ATX750i
ATX750i's Avatar
2003 Z4 2.5i  [0.00]
thanks, ill order a kit soon and post the results and performance here.
Johnathan
03' 2.5i Maldives Blue Roadster - SOLD
09' 2.0 Polished Metal Metallic Honda Civic Si - Current
