      05-31-2015, 01:45 PM   #1
Steenos
Drives: 2007 Z4M Coupe
2021 BMW M240i  [0.00]
2007 M Coupe  [0.00]
O2 Sensor Data, can you tell me what this means?
Trying a different set of cats on my car and I'm getting a CEL. I can see where the problem is in the data but I don't know how to translate the data cause I'm not a mechanic. Or I'm just talking out my ass. Anyone know what it should properly read?
2021 m240i on order
      06-01-2015, 07:23 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
I can read these off mine using my iPod.
I'll check them when I get home and let you know.
Off the top of my head, they look about right.
      06-01-2015, 09:33 PM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
It looks like I'm running rich on a hot engine at idle.
S12, S22: 0.755 - 0.770 V (they bob around a little)
I think they were both at 0.435 when I first started the car.
S11, S21: 2.00 V (don't bob around much)
S11, S21 mA: +/- 0.010 (they bob around also)
IIRC, S12 and S22 are the pre-cat narrow band and should optimally be 0.450.
S11 and S21 are the post cat wide band. The current should bob slightly around 0 as the DME adjusts it to maintain the voltage at 2.00 V.
