      05-27-2015, 07:30 PM   #1
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
X-Pipe and Muffler options
I currently have
VT2-525 supercharger
Euro catless headers
2.5" catless section 1 with small straight through mufflers. they reduce rasp
stock x pipe
stock muffler
Since I'm no longer using this as a daily drive, I want to make it a bit louder but not make it sound like a chainsaw. I'm ideally aiming for a "hollow" sound.
My options are:
1. custom X-pipe and stock mufflers
2. custom X-pipe and Corsa mufflers
3. stock X-pipe and Corsa mufflers
Is the car going to sound raspy if I mess with the stock X-pipe? Are there resonated aftermarket X-pipes?
      05-27-2015, 09:47 PM   #2
gmd2003
gmd2003's Avatar
352
Originally Posted by ZStig
I currently have
stock x pipe
stock muffler
My options are:
Keep the stock xpipe , and just change your mufflers .
      05-28-2015, 12:11 PM   #3
UntzUntzUntz
UntzUntzUntz's Avatar
Drives: 21 M2 Comp
Any option you go with will result in more rasp. You've already changed what prevents rasp, catless headers and catless s-pipe. So if I had to make a decision, only thing I would change are the mufflers for two reasons:
- weight savings (carry the OEM mufflers and you'd be glad you changed them)
- And rasp won't be as pronounced in comparison of changing the x-pipe
Whichever route you go with, the forum would like to see a video
      05-28-2015, 12:44 PM   #4
Reborn_
Drives: 2007 BMW Z4MC
I currently have euro header, DKF Section 1 with 300cell cat, stock x-pipe, and SS sport mufflers. I have a RE x-pipe (straight pipes - no resonator) en route. I will make some videos between the 2 setups and provide my feedback on sound after I do the install - should help you somewhat.
      05-28-2015, 01:32 PM   #5
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
In my opinion, the Rogue Engineering X-Pipe really brought to life the qualities of the S54 that I loved most. It's entirely opinionated, but I haven't found anyone on the road that hasn't liked it.
I've actually received 4 direct comments outside of car shows from people just cruising windows down over the road.
I'm running stock headers, stock section 1, rogue x-pipe, and RPI cans.
      05-28-2015, 02:24 PM   #6
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Mufflers first, then x-pipe. Generic mufflers usually don't sound as good on cars with catless headers and s-pipes. The cats hide a lot of the rasp and resonance... once you get rid of them, it a tuned system becomes more important.
I have a video of catless headers, resonated s-pipe, and Stromung mufflers. If you're interested, I can ask the car's owner to post it. I think RatedM had this setup too, so you might check out some of his videos.
      05-28-2015, 02:30 PM   #7
JCF
Drives: 07 Z4 M Coupe
The group buy for Stromung mufflers is still open if you're interested!
http://www.zpost.com/forums/showthread.php?t=1124901
      05-28-2015, 07:36 PM   #8
ZStig
279
not a fan of mild drone, which with my setup, would be moderate drone
      05-28-2015, 07:42 PM   #9
ZStig
279
thanks for your opinions everyone. The weight of the stock x-pipe and mufflers is definitely a concern. I've picked it up before.
Definitely going to keep the well engineered stock x-pipe for now, and look for muffler options. I'm leaning towards the generic Corsa muffler, because its design eliminates drone. here's how it sounds on an e46 m3
