      03-12-2015, 07:21 AM   #1
Poko
Drives: 2008 Z4 Coupe
Different type of muffler delete (3.0Si)
First of all sorry , no video , yet.
So i was thinking what made some muffler delete work and some don't and my conclusion was that i should avoid the "horn" effect by going into large diameter piping as well as to keep some back pressure.
so i asked the best local shop to build me a Y adaptor into a 2.5" single pipe and than another Y into dual tips.
The reasoning was that the 2.5" pipe with dual Y's attached to it should keep some back pressure.
I am VERY happy with the results. the car sounds amazing with a deep bass tone , it's loud but not obnoxiously loud and there is not a lot of drone (most of it is in the 3.2K RPM region). if you get off the gaz and just cruize you can't hear the engine at all.
to summerise - i think the muffler delete sounds better than any cat-back around , at least the ones i have. also most cat-back systems are with similar drone and i have had some that even droned much worse.
love it
      03-16-2015, 11:14 PM   #2
nemex12
Drives: e60,z4
looks pretty cool, any gains?
if you want perfection buy a mercedes, or marry an accountant
      03-17-2015, 11:28 AM   #3
Incompatible
Drives: 07 AW Z4C 3.0Si
Nice install. What's the length of the straight section between the Y adaptors?
      07-18-2015, 09:34 PM   #4
deemo319
deemo319's Avatar
Drives: BMW
What exhaust tips did you use?
Those look very nice. I am currently searching for some rolled tips or beveled tips for my exhaust conversion.
