05-31-2015, 12:12 PM | #1 |
Rep 115
CDV purchase
'07 MR
Late to getting around to replacing the CDV with a modified Zeckhausen version. As I recall, this was a $30 part in previous threads. Their site now reflects a price of $85 dollars (CDV-007). Anyone have another source. |
05-31-2015, 12:35 PM | #2 |
Rep 195
I remember it always being about $75-$80 from Zeckenhausen, but how about this:
http://www.ecstuning.com/BMW-Z4-M_Co....2L/ES2823106/ |
05-31-2015, 01:16 PM | #3 |
Rep 999
Assuming your car is out of warranty already? Just remove it and be done with; you might need to adjust the hose a little bit. Another option would be drilled out your original and make the ID larger.
No need to purchase anything unless the car isn't under warranty. |
05-31-2015, 03:58 PM | #4 |
Rep 131
Drives: 07 Z4 M Coupe
why not just remove it? It's a useless part...
05-31-2015, 04:25 PM | #5 | |
Rep 501
I'd never spend $85 let alone $30 for a "dummy" CDV. Just remove the CDV. |
06-01-2015, 02:09 PM | #7 |
Rep 195
Or if you want an excuse to buy something new, you can get a stainless steel clutch line. :-)
It requires a little more care in bleeding the system if you replace the whole line. On the plus side, you will see a cool blue stainless line every time you crawl under the car. |
06-01-2015, 07:28 PM | #8 |
636
Rep 3,124
No need to buy anything. The male/female fittings are identical, and there's plenty of slack in the hose.
