11-08-2012, 10:58 PM | #1 |
2152
Rep 5,011
..::PSI::.. G-POWER Z4 NON M Supercharger System SK I
Basis: Z4 2.2i/M54, 170 hp (125 kW) increased to 230 hp (169 kW)/ 260 Nm
Basis: Z4 2.5i/M54, 192 hp (141 kW) increased to 260 hp (191 kW)/ 310 Nm Basis: Z4 3.0i/M54, 231 hp (170 kW) increased to 333 hp (245 kW)/ 385 Nm Kits Include: - Ultra stiff CNC shaped supercharger bracket system made from cast aluminum including an extended support-aggregate belt drive for the superchargerīs drive - Air Intake Manifold, racing air filter with flow optimized clean air intake with large diameters made from cast aluminum. - Standard throttle valve is positioned in front of the supercharger inlet,this layout of the air mass control in partial load improves the fuel consumption. - ASA T3-313 supercharger - Supercharger lubrication through bypass from motor oil circuit. - 1 x air/water recuperater with front mount intercooler. - 2 x air collectors made from cast aluminum. - Engine inlet manifold made from cast aluminum. Boost level ~7.2 PSI Fuel Management/Electronics: - Adaptation of the software of the standard electronic engine control unite (BMW OBD remains fully preserved). - 6 x fuel injectors with enlarged mass flow. TOTAL: $ 8,400.00 with FREE shipping OR Installation at our facility. |
11-09-2012, 02:23 AM | #2 |
Rep 5,329
the design o these g-power parts is imo oem worthy.... gorgeous stuff.
Tags |
g-power, precision sport industries, psi, z4 g-power, z4 supercharger kit |
