06-26-2012, 05:02 PM | #1 |
Rep 862
How to take apart steering wheel controls?
So I am repainting my worn rubber steering wheel spokes to match the other silver trim.
I want to do a good job so after I took apart the volume control portion by removing the small torx screws, I couldn't get the volume/track button out! How do I remove the rest of the inside of the steering wheel controls so I can spray everything evenly? |
06-26-2012, 05:29 PM | #2 |
Rep 556
Drives: 2003 ESS TS1 Z4
On the top sides of your steering wheel there are 2 small holes. Put a long thin screwdriver in there and you will press on a spring. Its a strong spring so some force is needed. Once you find it push enough and pull on the airbag a little bit on that side, repeat on the other side. Once that is out you can lay it over the top. There are 2 more torx on the bottom ones. too, after those torx are all out you can just pull apart the plastic pieces. If you need more detailed instructions shoot me a PM with your number and Ill send you pics.
You can uplug your battery if you feel more comfortable.
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit. |
06-26-2012, 07:26 PM | #4 |
Rep 556
There should be 2 or 4 little clips that you have to push in on the sides. Good luck!
