06-03-2017, 08:00 AM | #1 |
Rep 870
Drives: 2006 BMW Z4M Roadster
WPC Rod Bearing Time
It's time for rod bearing replacement. My last two Blackstone reports were not good. I assume the WPC rod bearings are still the way to go. I see ECS has a set. Any recommendations, helpful hints? I haven't spoken to my indie mechanic, but would like to get someone to do this that has actual experience doing it. Maybe he has. We'll see. But, if not, are there any recommended shops that have experience with bearing replacement in North Carolina or South Carolina? I'm near Charlotte, NC.
Thanks! Salty
06-03-2017, 12:08 PM | #2 |
Rep 2,868
If you don't mind, could you post your Blackstone results? Thanks.
06-03-2017, 01:16 PM | #3 | |
Rep 820
Drives: 2007 Z4MR silver grey
SaltyNC369.50 |
06-04-2017, 02:13 AM | #4 |
636
Rep 3,124
That's what I'm running.
Andrew Lang says they're a good idea, and I'll defer to him. Also, he didn't like ARP bolts. I thought they were a good idea since they have the dimple in the end and the stretch gauge. Andrew said when he stretched them per ARP's recommendations on a test set of rods the bores were out of round. He had to stretch them a good bit more to get the bores round, and he wasn't comfortable with that amount of stretch, so he used stock bolts on mine.
Arsonism158.00 |
06-04-2017, 07:33 AM | #5 | |
Rep 870
What really concerned me in the last week is that I think the engine is louder than it has been in the past. It's not a knocking sound, but at idle, it just sounds different. I am going to put a stethoscope on it to see if I can isolate the sound. It could be the water pump making the noise. Someone posted a video of their water pump noise, and it sounds similar. Salty
Aux Port|LED Interior|LED Strip Trunk|Underseat First Aid Box|Stubby Antenna|Intravee II|BMW Oil Change Kit|Top Down Side Panels|Vibra Technics Engine Mounts|Rogue Trans Mounts|Engine Mount Bolts Upgrade|RS Windblocker|Euro Front Plate|M5 Illum Shift Knob|Supersprint Powerloop Exhaust|Gruppe-M Intake|RPI Scoop|Black Grills|19x8.5 ET35 F 19x9.5 ET22 R Sportline 8s PSS| Besian Vanos|CDV Delete Last edited by SaltyNC; 06-04-2017 at 01:03 PM.. |
Vanne1620.50 |
06-04-2017, 07:34 AM | #6 | |
Rep 870
Salty
antennahead72.50 |
06-04-2017, 07:41 AM | #7 | |
Rep 870
It has been quite awhile since I read it, but I was on a European board, and someone there believed the bearing issue was almost completely a result of start-up wear, and after a few revolutions of the engine, it was then coated in oil properly, but until then, it was basically running dry on those bearings. I thought it was an interesting idea, and thought it might come up on Zpost, but unless I missed it, it never did. Salty
06-04-2017, 07:52 AM | #8 |
Rep 870
Anyone familiar with these bearings?
http://www.bebearings.com/store/inde...products_id=27 Interesting discussion here about clearances: http://www.m3post.com/forums/showthr...202365&page=12 Salty
06-04-2017, 07:59 AM | #9 | |
Rep 870
Salty
06-04-2017, 12:25 PM | #10 | |
Rep 2,868
06-04-2017, 01:00 PM | #11 | ||
Rep 2,176
XMetal1143.50 |
06-04-2017, 01:16 PM | #12 |
Rep 11,668
^whs
Copper is the layer under lead. IMO, If you wait for copper you are asking for trouble. Just did mine with test showing 18ppm and lead was through to the point just before copper was showing.
XMetal1143.50 |
06-04-2017, 01:27 PM | #13 |
Rep 2,868
06-04-2017, 01:31 PM | #14 |
Rep 11,668
Nothing significant.
It was up 1 ppm my lead went from 2-4 range for several years to 18ppm this last sample
XMetal1143.50 |
06-04-2017, 01:32 PM | #15 | |
636
Rep 3,124
I read in a thread somewhere that somebody that makes camshafts determined that our bearings are about 2/3 as wide as they should be for the horsepower the S54 makes. So I figure they're sized for about 200 hp, which is about what you get at WOT at about 5000 rpm. So for DD use I keep it under 5000, with a dash up to about 6500 maybe once or twice a week to have some fun and blow some carbon out.
06-04-2017, 01:36 PM | #16 |
Rep 11,668
the other significant factor is proper warm up.
My indie says more than half of the rod bearings he does are on DD non-tracked cars. (S65 & S54)
06-04-2017, 01:40 PM | #17 |
Rep 2,176
Warmed up or not the bearings are way to small , only way to fix is to up size the journals and rod bearings like I did .
06-04-2017, 01:42 PM | #18 | |
Rep 11,668
I would love to do the same if it wasn't so expensive.
06-06-2017, 08:07 AM | #19 |
Rep 870
Any suggestions for other things I should do while the bearings are being replaced? None of my bushings have been replaced, so I'm thinking that would be a good idea. I was already planning on replacing the guibo.
Thanks. Salty
06-06-2017, 04:57 PM | #20 |
Rep 870
Audio of Knocking
Yikes! I heard this today. It went away after just a few seconds of the engine running, but I'm guessing this is a good warning to stop driving and get it into the shop. Do ya'll think this is rod knock? Bummer.
Salty
coh661191.00 |
06-06-2017, 10:51 PM | #21 |
Rep 10,675
Hmm, not quite sure but it doesn't sound like one to me (though my motor sure doesn't sound like that!). You'd need to give it a bit of gas for me to tell for sure. If that sound ramps up as you give it gas, I imagine that would be the dreaded rod knock.
06-07-2017, 07:15 AM | #22 |
Rep 870
NickyC, it actually diminishes in loudness as I accelerate, and it completely disappears soon after the engine is cranked and begins to warm up.
Salty
