      11-12-2017, 04:00 PM   #23
Over it
Mad Man
Drives: car
Hey Andre, did you ever solve this issue?
      11-12-2017, 04:14 PM   #24
dre99gsx
Drives: 1994 Toyota Supra
Yes, suspension settings, alignment and a wing out back.
      11-20-2017, 02:54 PM   #25
asleep636
Drives: '12 E92 M3, '07 E86 Z4M Coupe
"Keep in mind, I'm probably pushing 500whp right now"
WOW. What did you do to the Z4 to get 500 WHP? My Z4M has 330 hp at the Crank..
      11-20-2017, 03:09 PM   #26
dre99gsx
This link should answer your question
      11-20-2017, 03:16 PM   #27
asleep636
I saw that. I thought you have a final spec sheet that tells the current setup. Looks like you put in a S65 engine.
      11-20-2017, 04:09 PM   #28
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
what wing did you go for and size?
I would say 67 to 71" wing, with big splitter, with stiffer spring rates to compensate, upgrade front sway bar and put in stiffest settings, strut bar, and OEM rear bar.
that will most likely keep your car more neutral.
Alingments, make sure you get more caster over camber.....get as much caster as you can.
Instagram: ariusen26
Youtube: Track vids
      11-20-2017, 11:52 PM   #29
dre99gsx
What? You saw "that" but you still think I put in a S65? I thought the title of the thread linked and the "2JZ" plastered all over the build thread would give it away.
The last page includes a dyno chart as well.
      11-20-2017, 11:58 PM   #30
dre99gsx
I went with a 57" SARD BRZ wing. My car is stable at speed as long as I'm not under full power (I can cruise at 150 part throttle and it's solid). The issue came down to the extra torque given out by this motor at that high speed, which was probably causing all sorts of dynamics with rear squat, camber changes, and no aero to assist.
I did go stiffer springs (9k fr, 12k rear), more camber front and rear, and stiffer compression/rebound on the dampers. Add the rear wing, and it's been much much better. NOTE: I have more issue on the street where the road isn't flat due to tractor trailers and grooves. Don't ask me when I get to test on public roads...
