      05-25-2009, 08:22 PM   #1
jra
Drives: 2005 z4
Sport Button retro fit
Before I start...Mods I normally would not cross link to another z forum but I think that this thread is very educational for those of us who do not have the sport package option. If this violates any rules please remove.
http://www.bimmerfest.com/forums/sho...d.php?t=369531
So who is going to take a stab at it
      05-26-2009, 08:41 AM   #2
Chuck I
Chuck I's Avatar
Drives: '03 Z4 + '07 ///M Roadster
Hey, I've always wanted to try this... worse case, I'll end up with a button that doesn't do anything... I've got buttons I don't use anyway, what's one more!!! I just ordered the Sport Switch... I'll take pictures... Chuck I
      05-26-2009, 06:43 PM   #3
Chuck I
Chuck I's Avatar
OK.. the connector is there!
I thought about this all day... got home, removed the ashtray and button panel. I didn't see any cable. I then unsecured the gear lever cover and moved it to the side... I then started feeling the cables and noticed that the one on the left had two ends... one went to the gear shift lever and the other went under the carpet... I took a hook and pulled the carpet up next to the gear shift lever.... GUESS WHAT... There it was the connector for the sport button... My button is on order... when it comes in, I'm just going to plug it in and see what happens... I then have to cut the hole, but that's easy enough... I'll keep you posted... so far, this has taken about 15 minutes... Chuck I
      05-26-2009, 06:54 PM   #4
jra
Drives: 2005 z4
if it is that simple I will feel like a complete idiot as I have had my console apart more than a few times and never noticed the extra plug lol
      05-26-2009, 06:57 PM   #5
jra
Drives: 2005 z4
btw what is the part number for the button. thanks
      05-26-2009, 07:08 PM   #6
Chuck I
Chuck I's Avatar
Give it a quick look...
I was very surprised that I found it so quick... I lucked out... Give it a quick look and I bet you find it... Good Luck.. Chuck I
      05-26-2009, 07:11 PM   #7
Chuck I
Chuck I's Avatar
I ordered this one...
I ordered 61 31 6 915 010 Chuck I
      05-26-2009, 08:45 PM   #8
jra
Drives: 2005 z4
thanks for the part number.
I took the shifter cover off but could not find it, so I took out the console out and searched under the carpet...still can't find it. I also dont have the premium package so that may have something to do with it. I am going to dig some more tomorrow.
      05-26-2009, 09:41 PM   #9
Chuck I
Chuck I's Avatar
Here's another picture...
Darn... here's another picture... grab the wire that goes up to the shifter lights (where ist says P, R, N & D).... follow that down to the left.. you will have to stick you fingers down in there... you will come to a junction... one going to the right to the DME and one going to the left (mine was under the carpet)... you should be able to pull it out... I pulled it back through the same hole in the carpet that the wire going up the shifter uses. Hope the picture helps... Chuck I
      05-26-2009, 10:17 PM   #10
jra
Drives: 2005 z4
thanks for the pic, I went and cut the carpet apart and checked all of the wires, looks like I don't have the plug. Keep all of us updated. If anyone needs help taking the console out pm me.
      05-27-2009, 06:21 AM   #11
Chuck I
Chuck I's Avatar
JRA, what's the manufacture year and month of your Z4? I thought there was only one cable harness.. Let me do some research... Thanks, Chuck I (the Moderator may want to move this to one of the other forum sections...)
      05-27-2009, 06:21 AM   #12
gearl
Love My Car
Drives: 2006 Z4 3.0I
sport button
so what good is it just to have a sport button if you do not have the suspension to go with it?
      05-27-2009, 06:24 AM   #13
Chuck I
Chuck I's Avatar
Gearl, I had the Dinan S1 package put on my car last year.. That included all new springs and struts... I just looked at this sport button issue as a challenge since no one had figured it out.. It looks like folks have been playing with the idea since 2005... Chuck I..
      05-27-2009, 06:57 AM   #14
Chuck I
Chuck I's Avatar
JRA, I just checked and it looks like the Main Wiring Harness changes with the build date... darn... I'll keep checking though... Chuck I
      05-27-2009, 08:42 AM   #15
Hawkeye
Hawkeye's Avatar
No_Country
2070
The sport button doesn't change suspension, it changes the power curve a little bit. Makes the gas pedal more 'touchy' in the lower RPMs from what I can tell.
2016 GMC Sierra SLT Z71 Premium Plus 4x4
2017 Harley StreetGlide • Denim Black • V&H Tune
2021 BMW x30i • Phytonic Blue Metallic • Fully loaded
      05-27-2009, 08:47 AM   #16
gearl
Love My Car
that was my point it is kind of like taking off the 3.0si badge and replacing it with a M badge. When you order the sport package from the factory it comes with both the suspension and the shift change but it appears he has already upgraded his suspension.
      05-27-2009, 10:58 AM   #17
caseysc
caseysc's Avatar
Drives: 2010 128i Conv.
2005 Z4 2.5i  [8.00]
Here's what my '05 owner's manual says on sport mode:
Driving Dynamic Control allows your BMW to react in a sportier driving style at the touch of a button:
> The engine responds more spontaneously to any motion of the accelerator pedal
> The vehicle is steered more directly and traction is enhanced
> Cruise control:
When the speed last stored is called up, this speed is attained more quickly.
Additional features with SMG:
> Gears are shifted more quickly
> The engine speed range is optimally utilized in the drive mode.
With automatic transmission:
> The Sport program is activated.
      05-27-2009, 11:35 AM   #18
Ron Stygar
Drives: 2006 Z4 M Coupe
How many wires on the connector?
What colors are they?
      05-27-2009, 12:29 PM   #19
Chuck I
Chuck I's Avatar
I'll check when I go home tonight and let you know... Chuck I
      05-27-2009, 01:17 PM   #20
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
The sport button is just part of the sport package, are you going to knock me for adding in an auto dimming mirror when my car didn't come with the premium package?
The button changes the throttle and steering response, and changes how the car shifts with non-manual transmissions. Those things have nothing to do with the suspension or 18" tires. Adding a working button isn't a just cosmetic change that labels the car as something it's not.
jwolf63.00
      05-27-2009, 01:41 PM   #21
jra
Drives: 2005 z4
Chuck I, I really appreciate all of the help.
remembering that yours was an 03, as soon as I saw that the wire did not spilt I figured that it had to be build date related lol. good luck to you though. guess I will have to pony up for ess software.
      05-27-2009, 02:14 PM   #22
nickpapa
nickpapa's Avatar
23
Drives: Z4 3.0
Chuck I was is your build date?
