02-24-2015, 07:37 AM | #1 |
Rep 54
Z4 E85 Front License Plate mount/ is there a actual OEM??
Hi,
I have been looking for a BMW OEM front license plate mount/bracket and have yet to find one, did BMW have one for the US cars?? I have seen some of the aftermarket and they really do nothing for me and that one that screws into the tow hook socket I think that someone in the know could just unscrew it and walk away and also do not like its location. TIA, |
02-24-2015, 07:55 AM | #2 |
Rep 66
Drives: 06 Z4M Roadster; 2012 Cayenne
Yes, there is a BMW part for this, but you have to drill holes in the front bumper. Yes, someone could steal your tow hook mount, possible but not probable.
02-24-2015, 08:10 AM | #3 |
Rep 1,061
BMW sells a black one under part 51118041503 that requires painting. Put a feeler out on the classified board and you are likely to find one from another member that already painted.
02-24-2015, 10:02 AM | #4 |
Rep 54
Thanks!!!!!
BTW wouldn't the holder be covered with the plate anyway like the rear one? So would painting be necessary?? |
02-24-2015, 10:46 AM | #5 | |
Rep 501
02-24-2015, 12:58 PM | #6 | |
Rep 1,989
I would pick an option that allows the front bumper to remain unscathed... This is one option to use for the OEM bracket: http://www.bimmerfest.com/forums/sho...54&postcount=3 |
02-24-2015, 01:25 PM | #7 |
Rep 407
I've got the OEM tow hook on mine. Side plate looks more clean in my opinion.
Sorry phone camera isn't that great but I took this couple days ago. Oh and if someone steals a license plate tow hook bracket, you probably have a bigger problem. Consider moving lol |
02-26-2015, 11:30 PM | #8 | |
Rep 1,130
It's matches my car, sapphire black. PM me if interested, I'm sure we can workout a price |
02-26-2015, 11:33 PM | #9 |
Rep 747
I have on unpainted that I never intend to use. Classified may yield one that is painted as well.
02-28-2015, 08:56 AM | #10 |
Rep 1,543
I can see if I still have mine. I use a tow hook plate holder. If I still have the OE plate holder, you can have it. I'm in the Chicagoland area.
- Jeff
bosstones' flickr |
03-28-2015, 06:01 AM | #11 |
Rep 18,676
OP, sorry for bumping an old thread. Thought I'd chime in. I just got my E86 in December from CarMax and it had a CarMax universal front plate holder attached to the bumper. I like everything on my BMWs to be original equipment so I ordered the E86 license plate holder. When I got it I went to mount it and I didn't like it at all. It mounts the plate up high and covers up the bottom lip of the kidney grills, so I didn't like the way it looked. I stuck with the CarMax universal plate mount. I saw them stacked up on a shelf at the CarMax I bought my car from, so I'm sure you could get one from them if you still need to. I like the CarMax one because it sits behind the plate and make the plate look like it is floating just in front of the bumper.
03-28-2015, 08:33 AM | #12 | |
Rep 54
I picked up one of those tow hook mounts and do not like it! There cheesy to say the least and every time I have the car washed one of the guys usually hits it and then its tilted. Also it not mounted on one of the center holes there is a lot of flex and I'm afraid at speed the plate will bend back and one of the screws will scratch the bumper... The center mounting bolt (between the tow hook and license plate frame) I feel is way to small to really hold anything and I think one of these days it will just break off.
I have it tightened as much as I can as well as used blue lock tight w/ no avail. I believe that the E86 and E85 are two different mounts? Not at all interested in a aftermarket mount. I I wil just wait till I find a OEM one used Quote:
03-29-2015, 04:48 AM | #13 | |
Rep 18,676
03-29-2015, 10:18 PM | #15 |
Rep 1,543
I use Skene design. Have the bracket painted black and go as low as possible. It looks nicer than covering the kidney and bumper
http://skenedesign.com/FPBracket/index.shtml |
Tags |
e85 front license plate |
