      06-26-2017, 09:34 AM   #1
pcube
pcube's Avatar
58
Drives: Z4MC, G20 320i
Z4M tie rod replacement - outer end only?
While my car was up on jacks I noticed that the front right wheel had some lateral free play, which suggests that the tie rods need replacement.
Looked up realoem, and realised that there is no part number for the inner tie rod, only the outer one or the whole assembly (inner and outer with new nuts). Searched several online suppliers, and confirmed that it is not possible to purchase the inner tie rod separately.
So that got me thinking, perhaps it isn't necessary to replace the inner ones? What have you guys been doing? Replacing the whole assembly, or only the outer tie rod end?
Additional note: whole assembly is sold as original bmw (no oem alternatives) so rather expensive. Oem outer tie rod ends are available from Lemforder, which are much more affordable.
      06-26-2017, 12:07 PM   #2
The HACK
The HACK's Avatar
1821
Free play in the wheels can also mean wheel bearing.
      06-26-2017, 12:22 PM   #3
pcube
pcube's Avatar
58
Noise coming from a damaged wheel bearing would be quite obvious though. I have none of that... only a very slight pull in my steering.
      06-26-2017, 09:46 PM   #4
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
When you're wiggling the wheel, look at the rear end of the control arm for movement. A failed control arm bushing allows some lateral movement also.
Top Down 365
