      08-10-2010, 06:57 AM   #1
polaxgr
polaxgr's Avatar
Drives: with a highly modded iphone
Z4 M engine mount
Hi guys, i came across this in a greek forum. About problems of engine mount , right side of engine( co-driver side ). So i installed them. Has anyone does this ? Did i do well to change them ?
File Type: pdf Engine Mount Bolts - Service Bulletin.pdf (396.2 KB, 292 views)
      08-10-2010, 08:06 AM   #2
jragan
Imola Lover
jragan's Avatar
Yes, you did well to change them.
Hers: 997-1 C4S: Pics
      08-10-2010, 10:12 AM   #3
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
The long ones are for the passenger side (the weaker side), right? I'm going to do this asap. Was this difficult to do?
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      08-10-2010, 10:40 AM   #4
jragan
Imola Lover
jragan's Avatar
For the most detailed information (and the actual source of Ron Stygar's image above) head over to the FAQ on bimmerfest for the Z4Ms.
      08-10-2010, 10:52 AM   #5
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
I had two broken and three lose. I changed mine with the motorsport bolts illustrated above. There was one guy who had all bolts broken on one side of his car and the engine drooped to one side--not good.
You have to be 100% behind someone before you can stab them in the back.
David Brent
      08-10-2010, 11:35 AM   #6
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
There was this one guy who found 3 different types of bolts screwed into the passenger side at bimmerfest forum; I don't think that was supposed to happen. I got a little confused.
