      06-17-2014, 08:07 PM   #1
SHOR3N
SHOR3N's Avatar
Drives: 1M/Z4M/Jeep Rubicon Unlimited
LED license plate lights issue
Hello,
Does anyone have experience with LED license plate lights causing the light bulb error light to come on on the instrument panel? Any solutions? My came on after installing WeissLicht LED License Plate lights.
Thanks!
      06-17-2014, 08:38 PM   #2
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6332
no issues here. are yours bulbs or new panel replacments? i have R-dash with no problems or codes
instagram: @ dubsesd
      06-17-2014, 08:48 PM   #3
jafxdwg
Drives: 08 3.0si Artic White with Red
Leds are polarity sensitive.
Double check your installation first.
Confirm both lights are working.
Lastly - Check the other bulbs on the car. Could be just a coincidence that another bulb decided to screw with you.
Good luck
      06-17-2014, 11:57 PM   #4
Pheonix
2007 BMW/Z4MC  [0.00]
I also have R-dash and no issues at all.
      06-18-2014, 12:36 AM   #5
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
Well this is concerning considering my should arrive tomorrow. Hopefully I don't have any issues with this when they arrive. Will report on them whenever I do get them installed (hopefully tomorrow afternoon).
      06-18-2014, 09:24 AM   #6
M-Power M3
Retrograde
M-Power M3's Avatar
18
Drives: Bagged Z4
I have R Dash with no issues as well. You could have a bad bulb or a bad resistor in one of the bulbs. Try swapping the bulbs around to see if it's a polarity issue and if that doesn't fix it demand some new bulbs.
Bagged e85 Z4 | www.ogretrograde.com
Bagged TT 225Q SOLD - e46 M3 SOLD - W202 SOLD - e46 325i SOLD
      06-18-2014, 12:49 PM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
I don't think the license plate bulbs are monitored.
Make sure you didn't have any other bulb decide to go out just to mess with you.
      06-18-2014, 10:05 PM   #8
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
Just installed mine and I'm absolutely blown away at how bright those bastards are.
I have not gotten a bulb light and took it for about a 30 minute drive as well, I would look to your other bulbs to make sure they are all in working order as Stickmon suggested.
      06-18-2014, 10:19 PM   #9
SHOR3N
SHOR3N's Avatar
Thanks for all the input!
