      11-08-2015, 01:46 PM   #1
Jdp401
Drives: 2008 z4m sapphire black
Odd sized tires?
Hey everyone, new to the forum but not the z, had her for 3 years now. Got a question on tire size that no one else seems to be running. They are 275/40/18 and 235/45/18 on a set of vmr v703's 18x8.5 et 35 and 18x9.5 et 22. The car is on kw v3's adjusted to their highest setting, so about a .5 inch drop. The rears are rubbing a bit on the fender liner. I was wandering how much camber front and back would be needed to clear everything. The car is a dd with some spirited driving most days.
I like the look of thicker tires so I'd rather not go thinner.
      11-11-2015, 01:18 PM   #2
CryoEng
Drives: Z4MC, ZRX1200R
I don't have an answer to your problem, but I just ordered some wheels that are the same size and was considering an "odd sized" tire combination. Could you post some pictures of this combination? If you didn't have it lowered do you think you would still be rubbing?
      11-16-2015, 08:35 AM   #3
1Joel1
Drives: 2007 M Coupe, 2010 335d
I'm running 245/40/18 and 275/35/18 with no problems on my Z4MC with no problems.
Joel
      11-18-2015, 01:29 PM   #4
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Interesting sizing. You could always trim the fender liner a bit if you'd rather not mess around with your alignment settings.
