      09-25-2015, 07:27 AM   #1
SlimAndy
Taiwan
Drives: 2012' 1M Coupe VO
Z4M fitting with M3 gts wheels
Hi guys, I have a frd who has a spare set of M3 gts wheels with Re11 tires on it, specs are 19 x 9 inch, ET31 Front with 245/35/19 tires, and
19 x 10 inch, ET25 with 275/30/19. I'm wondering would this fit on my z4m? any idea! thanks
      09-25-2015, 07:37 AM   #2
Mtxzptlk
Driving Dog
Mtxzptlk's Avatar
871
Drives: 635/1815, X3M Comp
On stock suspension, Yes.
Expect slight rubbing on the fronts near or at full lock on the inner wheel well. Rubbing has more to do with 245 sized front rubber, I would think.
      09-25-2015, 07:18 PM   #3
SlimAndy
Taiwan
Thanks man?so the rear shroud be fine with 10J and this ET? I'm also worried about rubbing at the back
      09-30-2015, 11:48 PM   #4
Mtxzptlk
Driving Dog
Mtxzptlk's Avatar
871
19 x 10 +25 on the rear is bang on fitment on stock suspension.
Recommend you avoid kw cs coikovers if you decide to upgrade in the future and you plan to stick with this wheel set up.
