      10-21-2010, 10:37 AM   #89
SwapMag1c
Drives: 2004 Z4
any word of this for the Non-m?
      12-14-2010, 10:31 PM   #90
EMP07
EMP07's Avatar
37
Drives: Z4M
Originally Posted by kav View Post
Yup, after installing the Euro header I installed the secondary O2 sensors behind the secondary cats. I had problems initally when the shop I used cut the wires to extend them. I repalced both sensors and just unfolded the wiring harness out to length and it has been running great with no CEL!
What do you mean "unfolded the wiring harness"?
Anyone running euro/csl with removing the secondary o2 bungs?
Sorry to digress a bit.
      12-15-2010, 05:15 AM   #91
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
You should check the section 1 of your exhaust for cats (I haven't looked into it). If you have "secondary cats" (cats in section 1 as well as in your headers) you can weld an O2 sensor bung for the secondary O2 sensors right after the section 1 cats and the car shouldn't throw a code. I haven't heard of anyone doing this for the non-M Z4's, but if you check the M54 3-series forums you might find more info about it. S54 guys use the same trick to get around the SES light without buying a sim or tune.
      12-15-2010, 09:10 AM   #92
kav
Drives: Z4M
The 02 sensor harness was cut loose from the loom holding it to the rest of the wiring. This frees up a lot of length. So you can relocated it behind the secondary cats without having to cut or add length to the wires.
