04-27-2010, 04:28 PM | #23 |
Rep 421
Yeah, I actually think it will be a good diagnostic just to make sure the sim is working and installed properly before moving any of the o2 sensors and introducing the possibility of error there. Just wanted to confirm with the man himself. Let us know how the install goes. I should be getting it in sometime this week.
04-27-2010, 04:48 PM | #24 | ||
Rep 4,726
If anything I suggest not installing them, even after you have installed the headers, until you throw a CEL, that way you know the o2 sensors were installed correctly. IE the CEL should be for cat inefficiency not swapped sensors.
05-03-2010, 10:50 AM | #26 |
Rep 1,721
The Sim was really easy to install! Thanks O-Cha!
As for the headers though... I couldn't get the O2 sensors off the stock headers so I'm taking them to a shop to get removed. Once I get those off the stock headers and on the AA headers I'll be set.
BMW CCA Track Instructor
Join to win a M School Day at the Performance Center! Enter Referral ID: 420186 |
05-03-2010, 11:10 AM | #27 | |
Rep 4,726
Make sure you reinstall them with some antiseaze on the threads, don't get it on the sensor itself. Maybe the monkeys at the factory somehow forgot this step as I remember mine were harder then usual as well.
05-03-2010, 11:46 AM | #28 |
Rep 421
05-03-2010, 04:01 PM | #29 | |
Rep 1,721
I doing the sim and headers at the same time.
05-04-2010, 02:33 PM | #30 |
Rep 1,721
I took the old headers to my local shop yesterday to remove the O2 sensors and they did it in 2 minutes, didn't charge me a thing So I installed the AA headers last night. Why would anyone spend over a grand for exhaust cans that give +2HP when headers cost about the same and give 15-20HP and sound AMAZING! It sounds like I have a 6.2L V8 under the hood.
The sim is working perfect, no CEL at all. One problem though, since I installed the headers my windows are no longer one-touch going up. Could this be because of the sim or because my windows were down when I disconnected the battery? I don't really want to take a software problem to the dealer because they'll just void my warranty once they see the sim.
05-04-2010, 02:39 PM | #31 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
Good to hear how good they sound! Mine(cross fingers) will go on Saturday. Putting on under pulleys tonight. So do you think it's possible to get the 02's out with some pb blaster?
05-04-2010, 02:43 PM | #32 | |
Dark Sider
129
Rep 1,779
http://www.zpost.com/forums/showthread.php?t=62834 "Initialization is performed on the power window switch of the relevant door. Requirements for correct initialization: • Initialization with engine running • Convertible top, doors and windows closed Initialization comprises: • Erasure of initialization • Reinitialization An initialization must be performed: • In the event of malfunctions, e.g. no one-touch control function, no opening or if available no comfort function is possible • After the power window drive has been replaced • After work is carried out on the power window mechanism • After a power supply interruption, e.g. disconnection of the battery or disconnection of the power supply to the door • After the door window glass has been removed and installed or replaced • After adjustment work on the door window glass • After adjustment work on the convertible top • After replacement of seals Erasure of initialization: • Open door window glass fully • Operate power window switch in "Open" position four times within 10 seconds This erases initialization of the power window, anti-trapping protection and toll function are inactive. Check whether one-touch control (toll) function is inactive, otherwise repeat procedure. Reinitialization: Avoid a break between the two steps! • Open door window glass fully • Operate and hold power window switch in "Close" position (second switch stage) • Once the upper end position has been reached, hold power window switch in "Close" position for approx. 2 seconds longer • Open door window glass fully • Operate and hold power window switch in "Close" position (second switch stage) • Once the upper end position has been reached, hold power window switch in "Close" position for approx. 2 seconds longer" __________________
05-04-2010, 03:22 PM | #33 | |
Rep 1,721
Thanks for the window tip!
Join to win a M School Day at the Performance Center! Enter Referral ID: 420186 Last edited by DarkstarZero; 05-04-2010 at 04:29 PM.. |
05-04-2010, 04:15 PM | #34 |
Dark Sider
129
Rep 1,779
I need the sims now myself. Powerchip can't shut off the 02's cause they fired all of their programmers. I was getting it done for cheap too because I have already gotten their intial tune. So now it's either sims or a $800 reflash from someone else. I was hoping to get a few extra HP's from the tune but I just cant swing it $$$ after the $$$ headers.
05-04-2010, 06:55 PM | #35 | ||
Rep 4,726
05-06-2010, 02:37 PM | #36 |
Rep 421
I've been wrestling with my rear o2's for the past hour. PB Blaster galore then finally resorted to gentle use of the torch to heat the bung. No dice. FAHHHHHHHHHHHHHHHHHHHHKKKKKKKKK
05-06-2010, 03:48 PM | #37 |
Dark Sider
129
Rep 1,779
Ugh. Im not looking forward to this. ETA Saturday morning.
05-06-2010, 09:39 PM | #38 |
Rep 421
Good luck! I'm sure its a matter of mileage, environment, usage, etc. as to how badly seized are the rear o2's. I made the mistake of trying to remove them after having taken the headers off the car. At that point its really hard to get good leverage without the header moving around. If you have a good table vise, probably not a problem. If not, try to break them free while the header is still attached to the head.
If anybody has a trick to removing the header nuts without the studs backing out please post it for the benefit of others. I ended up pulling 14 studs out of the head and only 4 nuts cleanly. Another PITA of this install |
05-06-2010, 10:26 PM | #39 |
Dark Sider
129
Rep 1,779
How many miles on you ride? The stud deal sounds wonderful
05-06-2010, 10:34 PM | #40 |
Rep 421
27k, year round driver though. Just set aside a whole day for the install. The people that tell you 3 hours have either done it multiple times and know all the tricks, have a lift, have a bmw tech as a helper, are full of shit, or all of the above. Either that or they're freaking ninja-type mechanics
05-07-2010, 12:52 PM | #41 | |||
Rep 4,726
If you have the proper tool (IE not a 2 sided wrench but a multi sided O2 socket wrench). put it on there and use the handle of a jack to serve as an extension. In regards to the studs puling out, use PBblast on them and let them soak. Other than that there's no special trick. If they do pull out make sure you put them in before tightening anything else down and alternate snugging each stud back in to insure you don't break the nut loose while tightening resulting in poor stud to head engagement. Also, I have pulled off a header swap on a Z4M in less than two hours, you can hate me if you would like.
05-07-2010, 01:30 PM | #42 | |
Rep 1,721
05-07-2010, 04:33 PM | #43 |
Rep 421
05-16-2010, 01:42 PM | #44 |
Dark Sider
129
Rep 1,779
100 miles with headers on and no sim + 200 miles with sim= no codes or engine lights. Looking good!
