03-27-2018, 01:26 PM | #1 |
Rep 226
Coupe rear-view mirror height/angle
I've just got a Coupe and the one thing I cannot get over is the height/angle of the rear-view mirror. I'm 6'1" and when sitting normally and a car driving at normal spacing behind me, I can't see beyond it's headlights. I can slouch a bit and see more, but that's no fun.
I searched and didn't come up with much complaining, just a bunch of mirror swaps for the auto-adjust, but surely someone has done something about this? I'm thinking lowering the mirror a tad should give me a better line of sight out of the back window. An other option is to just keep alot of pressure on the skinny pedal and not worry about what's behind! |
03-27-2018, 02:18 PM | #2 |
Rep 1,031
I find putting a wing on the trunk helps .. well with stability, not really with visibility though
before the wing I would almost tilt the mirror fully up and use just the bottom of it to see behind me. after wing .. I gave up and use side mirrors only.
03-28-2018, 11:58 AM | #3 |
dances with roads
4732
Rep 4,096
Interesting observation. I have a 3.0si and an M coupe, and I can see much further behind me in the 3.0si. I'm pretty sure I have the seats at the same height, so I've been meaning to take some measurements of mirror location.
03-28-2018, 01:11 PM | #4 |
Rep 679
The back window looks almost like a mailslot through the mirror. Im 5,11 and found using mirrors and shoulder checks when changing lanes makes it easier. U will get used to it.
03-28-2018, 02:14 PM | #5 |
Rep 226
I feel that the mirror would be much more useful to me if it were an inch lower then the angles would work better for me. It's acceptable to me if I slouch down a bit and I think my seat is as low as it will go.
I'm sure I'll get used to it; in fact I find myself not using it at all already. Maybe I need to get the wing! |
Mirko182.00 |
03-28-2018, 05:43 PM | #6 | ||
Rep 2,547
I also have a pair of these to reduce blind spots, where the outer 1/4 is fisheyeish: |
wdb4732.00 |
04-01-2018, 02:01 PM | #7 |
Rep 451
I have the same issue as OP. Being 6'2" getting the right angle on the mirror is impossible. I have a hard time with seeing the street lights too at some intersections, but that's a good thing. Now I slow down and try not to be the first to the light.
Instagram: @dasianoak
04-01-2018, 03:42 PM | #8 |
Not a New Member
94
Rep 925
I'm also 6'1" - I'd much rather have a non-functional rear view mirror than have reduced visibility out the windshield due to lowering the mirror any.
04-01-2018, 08:47 PM | #9 |
Rep 71
Another option, after lowering the seat, is to recline it a bit more.
I find this makes a significant difference in the height of my eyeballs. I’m 6’ 0” |
