      07-30-2017, 09:17 PM   #1
Our03z4
Drives: 2008 BMW Z4 3.0si Coupe,
Engine problem getting worse! Puzzled...
Can't figure out what is going on with my Z4 2.5 manual. The car has been acting like it wants to stall at take off sometimes, this happens when the car is up to temp. That has been going on for a while but now it's actually stalling, did it three times today after a 5 min idle when I went to take off and also stalled twice at start up. When I was going about 60mph it sputtered twice. I use top tier 93 fuel. Also have already done plugs, wires, vanos, coolant system during this and none have made a difference. Could a bad battery be the cause? It's 6 years old so I am getting a new one any ways. Seems to be worse if the a/c and headlights are on so makes me wonder or it could be just a higher load on the engine. Bad oil level sensor? No dash lights on either other than the air bag light.
Thanks for any thoughts!
      07-31-2017, 01:27 AM   #2
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Fuel / air / spark / timing.
If you run through a tank of gas each month, it's probably not bad gas. A stuck injector is unlikely although still a possibility, but you would have misfire codes and a check engine light. Since your issues are at idle, I doubt it's a fuel pump or clogged filter. When did you last change your air filter?
My troubleshooting recommendations, in order:
1. Try pulling the codes. Sometimes pending codes are stored which don't trigger a check engine light.
2. The intake boot has a tendency to crack. If yours hasn't been replaced, I'd consider it, or at least check for vacuum leaks.
3. An O2 sensor or your MAF sensor may be on its way out. Once the car is warmed up, you can unplug the MAF sensor (which will throw a check engine light), but it may help isolate the problem. If the car runs fine with the MAF sensor unplugged, more than likely you either have a bad MAF sensor or a vacuum leak (see #2).
4. The rubber on our cars is getting old and brittle. Consider checking all vacuum lines, including those to the idle control valve.
      07-31-2017, 06:42 AM   #3
Steeler
Steeler's Avatar
2429
similar issue here
http://www.zpost.com/forums/showthread.php?t=1400606
      07-31-2017, 09:31 AM   #4
Our03z4
Thanks so much everyone! Just checked the intake and the smaller off shoot line after the maf is almost in half it's so bad. Also found cracks in most tubes so I'm amazed it even runs at all. Thanks again!
