      08-12-2015, 02:06 PM   #1
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
First HPDE, installed RS-29 pads. Need help
I installed RS-29 pads for my first HPDE. The pads held up nicely with no fade.
I had shaking/vibration of the steering wheel under medium/heavy braking. I don't think that I beat on the brakes too much (if anything, I was underdriving). Could this be because the brakes didn't got hot enough?
Also, there are now some loud rattling sounds coming from the brakes. Cyclical in nature, gets faster as speeds increase. Mostly noticeable at low speeds, like in the pit lane. The sound goes away if I lightly touch the brakes but return after I lift my foot off. They didn't rattle like this when I installed them.
I plan to check some things this week but am wondering if anyone has some tips beforehand.
      08-12-2015, 02:29 PM   #2
The HACK
The HACK's Avatar
1821
The vibrations are typical of high end track pads. They tend to leave behind uneven deposits if they are not bedded in properly. Try going through a couple of deep bedding in cycles as recommended by the pad manufacturer and it should go away.
The rattle is also typical of high end track pads, some of them come without the 3 prongs on the back of the inbound pads, and will float around inside the calipers once they've worn down slightly. You can either apply copious of the anti-squeal goop on the "ears" of the pad to force it to stay in place, or just "live with it."
      08-12-2015, 02:33 PM   #3
intoflatlines
Thanks. On the RS29 the rears did not have prongs but the fronts did. I'll check to see confirm the sound is coming from the front or the rear.
