07-04-2013, 04:04 PM | #23 |
Rep 2,138
Drives: Me
You should see 12V at the jump start terminal (the big silver nut on the firewall). It is directly connected to the battery.
http://www.shipkiller.com/Battery_System_Schematic.pdf Since you have no power to the fan connector, you need to ohm out (continuity check) the wiring of the circuit. I would ohm out the power wire, from pin two (2) on the fan plug (X1800) to the fuse block. I would then ohm out the ground from pin one (1) on the fan plug to ground. These ground wires go to a common ground buss point. I am having issues with my WDS so I will tell you were the ground point is after I get my java issues fixed. |
07-04-2013, 04:57 PM | #24 |
Rep 2,138
Drives: Me
The ground buss for this (X166) is located on the strut tower....
Here is a picture: http://www.shipkiller.com/images/X16...und%20Buss.png |
07-04-2013, 11:33 PM | #25 | |
instagram 997turbotom
279
Rep 7,376
07-05-2013, 07:02 AM | #26 |
Rep 2,138
Drives: Me
Not sure why this happened. If does work from the main engine cooling menu on the site.
See if this works. http://www.shipkiller.com/images/X16...und%20Buss.png |
07-05-2013, 11:18 AM | #28 |
279
Rep 7,376
ok well, apparently I need a new fan
I wasn't getting power on the connector when it was disconnected to the fan, but when connected to the fan, and I prodded in there, there is a 12v signal. The connectors on the fan itself have 0 resistance.
07-05-2013, 11:19 AM | #29 |
Bad Lieutenant
232
Rep 3,517
Damn that's weird, I can probably count on one hand how many times my fan even activated on the hottest days. I would think it would last longer, they are not cheap.
07-05-2013, 11:27 AM | #30 | |
701
Rep 7,850
ZStig, that stinks the fan bit the dust but I guess you have a diagnosis and repair plan now. |
07-05-2013, 12:00 PM | #31 |
279
Rep 7,376
yup. I'm thinking of going with an aftermarket fan. The stock one is $530 + shipping
Anyone know the flow rate of the stock one?
07-05-2013, 05:25 PM | #32 | |
Bad Lieutenant
232
Rep 3,517
07-05-2013, 06:43 PM | #33 |
279
Rep 7,376
This is the fan I ordered. Will be here tomorrow. Thank God for Amazon's overnight shipping
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
07-05-2013, 10:26 PM | #34 | |
Bad Lieutenant
232
Rep 3,517
07-06-2013, 10:17 AM | #35 | |
279
Rep 7,376
Not sure if E46M3 people use this. Hoping it will actually be an improvement over stock, which would help keep things cooler under the hood and increase power on my super heat-sensitive setup
07-06-2013, 10:29 AM | #36 |
279
Rep 7,376
the only thing that worries me is it will be running at 100% all the time, which might get annoying, BUT if it does get annoying, I'll get this kit:
http://www.amazon.com/Flex-lite-3116..._huc_mrai_3_dp I'm also gonna try to integrate it into the OEM fan shroud
07-06-2013, 10:51 AM | #37 |
Rep 2,138
Drives: Me
ZStig,
I removed my engine driven fan and installed two big modo fans with dual controllers on my F-150, and ran them for nine years. If you go the fan controller route, there are some gotchas to be aware of. 1. Controller mounting point is key. Put the controller in some type of waterproof box. I went through six controllers. No matter how well you think you have it waterproofed, water always finds a way in and destroys the controller if it is not in a box. Your fan has 11 amps of draw after start. I bet it's close to 30amps for startup current. Mine were 14amps running and 30amps startup, each! With that much current, any water will destroy the controller. Sometimes in quite spectacular fashion.... When you set the temperature set points, try to sample what the ECU is reading for temp. That way you can get as close as possible to what a normal fan will start at. Plus, its more accurate than using a thermometer. |
07-08-2013, 02:37 PM | #38 |
279
Rep 7,376
I got the new aftermarket fan in there, but the car is running warmer than stock by 10-15 degrees if I drive it hard. Maybe its because the stock fan is 19", and this one is only 16". It seems to blow hard, but obviously its not good enough
Does anyone know of a place I can send in my broken OEM fan to get repaired?
08-06-2019, 10:59 AM | #39 |
Rep 12,559
Garage List F15 X5 xDrive35i [8.33]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.33] E82 135is (Retired) [9.46] E85 Z4 M (Retired) [9.33] E90 328i xDrive (Re ... [9.00] E86 Z4 3.0si (Retired) [9.18] |
Bump anyone else have this issue? The DIY for replacing the fan looks really simple. All the years have been on here though, seems so random relative to other issues. New fans only $100 but has anyone else needed to deal with this? Error code I got was 2F71E
