      12-06-2011, 09:30 AM   #1
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
Style 264 1 Series on Z4
Has anyone installed these? The specs look like they "should" work. Would like to get a set and powder coat black.
Thanks all!
Chris
      12-06-2011, 09:31 AM   #2
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
Oh, and I have a 2005 2.5.
      12-06-2011, 09:37 AM   #3
v3.0si
v3.0si's Avatar
Drives: '08 Z4C 3.0si
the front will look very tucked... you may want a spacer to get them back to stock look, and will definitely want spacers if you want them flush.
the rear will look nearly stock. at only a 2mm difference i'm not sure it would be noticible. again, you'll need spacers to make them look flush.
      12-06-2011, 09:44 AM   #4
v3.0si
v3.0si's Avatar
i should clarify mine from above... the "look" is relative to the OEM 18" sport pkg setup...
frt 18" x 8.0" et47
rear 18" x 8.5" et50
      12-06-2011, 10:11 AM   #5
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
Thanks for the info v3.0si!
