      07-22-2019, 04:21 PM   #45
Rekla
Hug the road... Carpe Asphalt
Rekla's Avatar
Drives: 2007 ///M Coupe
Ordered the ROAD Vibra Technic motor mounts today. I already have the Rouge Engineering Tranny mounts installed - they improved the overall shifting but didn't do much to smooth the 2nd gear transitions. I hope in combination with the VT-motor mounts the 2nd gear transitions will be smoothened out - seems like most of you are confirming this,
Any installation guidance on the Motor Mounts as I will be DIY?
I have a QuickJack that will make the job easier
Can someone identify the bolts I should replace?
Thank you in advance!
2007 BMW ///M Coupe
      07-26-2019, 02:19 PM   #46
StickMon
StickMon's Avatar
Drives: 2006 MR
Now see here.
Post #16 by JimBob0047 has the part numbers.
