02-06-2012, 10:44 PM | #1 |
tosser
32
Rep 988
ideal setup for daily and track wheels
all,
the OEM zedM rims are great but i want to change things up a bit. i got a set of 19" RGR's from a forum member which i'll use daily. they have the 20mm rear offset so i'm a little weary about how low i can go without rubbing issues. before spring rolls around, i'll get a set of 18" advan RS-D's in matte black. these will be my track wheels. do you think an adjustable coilover setup might be best? considering i would not be able to sit that low with the RGR's and would like to lower on track days. H&R coilovers? or maybe just springs...though i'm not sure how they'll sit with 19x10et20 in the rear. suggestions/advice appreciated. noob status
'07 MCoupe lots of mods |
02-09-2012, 10:53 PM | #2 |
tosser
32
Rep 988
i'll reframe my question:
i plan on running three sets of wheels and interchanging them often. 19" RGR's for daily. 18" advans for track. OEM should i feel the need. this means i'll likely need to change ride height and stiffness settings often as well. what would be a user friendly setup to make this possible? maybe just H&R coilovers?...but i don't know about their ease of use. in my search i came up with PSS10's being very easy to adjust. they're a little pricey though.
02-09-2012, 11:15 PM | #4 |
tosser
32
Rep 988
i could. i just really love the RGR's for a daily look. i'm not saying the advans can't be run off the track..but just a 'general' allocation.
02-10-2012, 09:51 AM | #5 |
instagram 997turbotom
284
Rep 7,377
10" wide and 20 offset? You'll stick out by a bit unless you roll the rear fenders. I think. Check the official wheel thread
have you mounted them yet?
02-10-2012, 10:17 AM | #6 | |
tosser
32
Rep 988
this is how my car will look before a drop. i think it's manageable without rolling, no? a subtle 1" drop.. http://www.zpost.com/forums/showthread.php?t=629084
02-10-2012, 12:01 PM | #7 |
284
Rep 7,377
dude, they're obviously sticking out PAST the fenders. If you lower it an inch, the fender will hit the tire. If you wanna lower it running that setup you either need to roll your fenders, and/or run 265mm in the back
02-10-2012, 12:14 PM | #8 |
Rep 2,747
^ +1
tire size will be key.
02-10-2012, 12:35 PM | #10 |
Member
17
Rep 178
The rim is not the problem, its the square side wall of the Michelin Pilot A/S that you're running. I'm currently running 19X10 witih a 20 offset (275/30) with no rubbing (more than a one inch drop) on and off the track.
02-10-2012, 02:52 PM | #11 |
tosser
32
Rep 988
that wasn't my car btw...just an example i found searching. damn similar thouh, same rims, same car, same color, same offset.
what tire are you running?
02-10-2012, 04:34 PM | #12 |
1821
Rep 5,337
Why would you EVER want to change the ride-height once it's been set properly? If you change the ride height between each wheels you'll have to get it re-aligned and re-corner balanced each time otherwise the car will handle like sh*t.
IF the biggest concern is over the 19" RGRs, set your ride height for that wheel, get the car corner balanced and aligned, and leave it alone for the track and the other set of wheels and tires and adjust camber up front accordingly for various use. Unless your getting coil overs for stance and looks only.
02-10-2012, 08:04 PM | #13 | |
Rep 2,747
Good info, I second. The HACK is a great resource for this sh*t
02-11-2012, 09:41 AM | #14 |
Wagon life
39
Rep 991
Rolled fenders? What kind of tires and do you have pics?
02-11-2012, 06:29 PM | #16 |
M = Midlife Crisis
66
Rep 2,006
Yup! The HACK cuts through the usual Car Internet forum BS
2006 Z4MC - #LL93158
02-11-2012, 09:46 PM | #17 |
#dubspec
6344
Rep 5,201
Different tires will fit better. My hankook v12 are great for the street, and don't buldge out past the rim at all.
02-11-2012, 10:22 PM | #18 | |
Member
17
Rep 178
02-12-2012, 04:17 PM | #19 |
tosser
32
Rep 988
thanks..i'll do some digging.
02-12-2012, 06:02 PM | #20 | |
Rep 4,531
