      03-14-2010, 01:55 PM   #1
buddrinker
buddrinker's Avatar
Drives: Bmw Z4 3.0i
Upgrading to bigger Injectors
I was wondering if anyone with a 3.0 engine has tried to upgrade their fuel injectors to make the engine put out the same as a z4 si. I think you would also have to get your computer reprogramed. Both engines are identical. If anyone has any info that would be great.
thanks
      03-30-2010, 06:47 AM   #2
CBull
Drives: 07 3.0i
I’ve bin trying to find out my self is it possible to convert a 06+ 3.0i to si specs. I assume different sensors, injectors and ECU are needed, I’m not sure if there are any mechanical differences in the heads (i.e. Honda’s Vtec engines). If anyone out there knows more I’d love to get that extra 40hp.
      03-30-2010, 07:40 AM   #3
CBull
Drives: 07 3.0i
Found the answer to my question over on the E90 forum 328 to 330 is the same as 3.0i to 3.0si.
Sticky: Tech Info: E90 330i N52 Three-Stage Intake Manifold
      04-12-2010, 01:02 PM   #4
SSG S
Drives: DINAN Z4
a link?
      04-13-2010, 06:16 AM   #5
CBull
Drives: 07 3.0i
http://www.e90post.com/forums/showthread.php?t=37444[/URL]
