02-16-2014, 04:56 PM | #1 |
Rep 2,176
What cc injectors came with you're ESS VT 500/525 kit
Guys i finally got my car right mechanically , no belt slip , new,
Vanos , full Catless exhaust etc. dyno tested this past week and had horrible AFR's almost 14 after 7K rpm ( until that point they were 11.5) . My first instinct was to blame the new aeromotive fuel pump , but i decided to look at all possible causes in the fuel system . When i checked the part number on my Bosch injectors on their website i found out that they are only 350cc/min !!! WTF , thats a major problem as , running calculations estimate they would be 100 % maxed out at 480 crank , much less 525+ . Ill talk to Roman on Monday but i smell another fuck up . Just glad my motor has not blown . Either this is another part f up or ESS has grossly miss sized the injectors on the 525 kit . We are stuck bc going with a larger injector while def require a new tune . Im honestly this close to burning this kit in my back yard . George |
02-16-2014, 05:27 PM | #2 | |
Rep 912
02-16-2014, 05:47 PM | #3 | ||
Rep 2,176
George |
02-16-2014, 05:56 PM | #5 |
Rep 892
You're going to need much larger injectors and a new tune. Your IDC with these are likely near 100% (well before it leans out); even 100cc larger injectors would be 90+% IDC and would still cause lean conditions...
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i |
02-16-2014, 06:06 PM | #6 | |
Rep 2,176
02-17-2014, 04:00 AM | #7 | |
Rep 912
I stopped driving my car and will install new rod bearings, head gasket and ARP everything. an ATI damper from VAC, oil pump upgrade and the whole engine refresh, head gasket set and crankcase gasket set. I don't believe this "stock engine can take it" ideology, as well as "this kit was tested for 50 000 miles". |
02-17-2014, 06:32 AM | #8 | ||
Rep 2,176
George |
02-17-2014, 07:39 PM | #9 |
Rep 2,176
Well its confirmed, I received the 350cc injectors by mistake . They use the 350cc on the VT1 ( fine) and the VT -2 500 ! ( Not fine!) The 525 kit is supposed to have 420cc injectors ( i honestly hoped they were 550 but they should be ok ) . The part number on the correct Bosch injector is 0280156012. They really like to use injectors with no safety margin , don't know why .
George |
02-17-2014, 08:37 PM | #10 |
instagram 997turbotom
279
Rep 7,377
I'd be mostly glad that you don't have to touch that fuel pump. much more involved. I'm glad you were able to figure this out. I really hope they don't use the same injectors on the Vt1 kit and the Vt2 kit (mine), even though I'm at only 7psi boost
what boost are you peaking on?
02-17-2014, 09:05 PM | #11 | |
Rep 892
02-17-2014, 09:06 PM | #12 |
10834
Rep 4,890
Wouldn't the mapping be all wrong with wrong size injectors?
So not only the afr at high revs but also at low revs? I mean: there is a direct relation between the fuel mapping and the injector size, isn't there? I mean if your afr drops to 11,5 in midrange, that is clearly a mapping that is adjusted for those 350cc injectors, isn't it (afr 11,5 is good)? And if the afr rises too high in the high revs, its that the duty cycle is/needs to be over 100% to deliver that power (aka injectors too small, but the mapping is written for those injectors). Or is there something I'm missing?
02-17-2014, 09:28 PM | #13 | |
Rep 2,176
The only kit that gets the 420 is the 525 . Id like larger than 420 for mine , but we are in jail with our tunes . Im seeing around 7.5 psi , but im full catless, thus lower boost pressure and higher flow . Another reason why my car was running leaner than most . I was still expecting 8 psi catless so im going to pressure check again , i may have a small leak after 7 psi . |
02-17-2014, 09:30 PM | #14 | ||
Rep 2,176
02-18-2014, 12:39 PM | #15 |
Rep 2,176
Ok so update from ESS. Per usual the customer service side of things is excellent, from both AJ and Roman. So I had one of the first 525 kits that was actually designed for and tuned for 350cc injectors. AJ said this worked for up to 430whp, the problem is with SS headers and no cats mine tried to make 460whp. So they are expediting me new larger injectors and new tune designed for the larger injectors. This all makes sense bc looking at my current midrange AFR's things look like they were tuned for that size injector. So for all those with headers and a VT-2 anything, if you are having lean issues don't assume it's your fuel pump , you need to make sure your injectors are able to supply enough fueling.
George |
02-18-2014, 03:55 PM | #16 |
10834
Rep 4,890
So my technical deduction was sound after all
02-18-2014, 07:38 PM | #18 | |
Rep 2,176
02-19-2014, 05:14 AM | #20 | |
Rep 2,176
George |
02-19-2014, 11:42 AM | #21 | |
Rep 912
Earlier i had a boost leak and was having wonderful AFR due to the dynamic calibration of the AFR but after fixing the AFR i am having lean conditions with a 500 hp crank cap .. |
02-19-2014, 01:29 PM | #22 | ||
Rep 2,176
