10-28-2013, 12:54 AM | #45 | ||
Rep 219
Drives: 2007 BMW Z4 M Coupe
Garage List 2000 Volve S70 se [0.00]
2000 Triumph Dayton ... [0.00] 2007 Husqvarna TE250 [0.00] 2002 Ducati Monster ... [0.00] 2007 BMW [0.00] |
Pictures certainly show the passenger side mount has not only separated from the hardware, but has significantly deformed when compared to the driver's side. It looks like it's melted in an oven (AKA: Dallas!). I was seeing the orangish-growth as something oozing from the polyurethane as it was being subjected to high heat and moisture, certainly changing the resiliency of the material in some way. I certainly could be wrong as it's only a visual impression and I don't have the mount to physically examine. Whatever it is - it looks awful! As far as re-routing the drain: I will certainly be adding that to the 'to-do' list and using some of the suggestions described here. Thank you StickMon! |
