08-14-2012, 10:12 PM | #24 |
Bad Lieutenant
232
Rep 3,517
MTL makes a great difference in the ZF tranny, at least in my climate anyway. Interesting points on the additive; I now have something to occupy my research time.
08-14-2012, 11:29 PM | #25 |
Rep 251
Yeap Yeap.... I've been using Red Line in my Trans and Diff... for close to 4000 mile.
Made shifting a bit smoother... I might feed the S54 some Red Line as well on my next oil change. |
08-15-2012, 12:57 PM | #26 |
Rep 660
how about RP (royal purple)? i've been using royal purple on LSD and tranny
Future mod consideration: exhaust, pulley
otherwise, very happy with how the m3 was born |
08-15-2012, 01:03 PM | #27 |
Rep 251
08-20-2012, 05:41 PM | #28 |
Resident Tamed Racing Driver
298
Rep 4,697
The basic summary is that if you drive your car for the looks, other oils are good. If you drive your car hard, you need Castrol TWS 10W60.
Read the E46 section oil thread. Lots of very good information from Castrol engineers who were present for the development and other BMW insiders: http://www.m3forum.net/m3forum/showthread.php?t=295656
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
08-20-2012, 10:19 PM | #30 |
Save the Manuals
1714
Rep 2,937
EC fluids upgrades and dyno tests
This makes me feel better about Redline in the M-R I use the 0W-40 LubroMoly in my 330i and it runs flawlessly. The TWS dynasty is over.
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
08-21-2012, 09:57 AM | #31 |
298
Rep 4,697
I just can't imagine why on a $50,000 car one would want to risk skimping on a few bucks.
08-21-2012, 10:54 AM | #32 | |
Rep 376
It's about evaluating all options to find one that reduces rod bearing wear. I could care less whether or not I save a few bucks or even pay more. I want the lowest wear numbers on UOA so I'm not swapping rod bearings at 60K. If TWS is the holy grail of 10W-60 oil it should return the lowest wear numbers and I plan to let UOA be the judge. In my mind the biggest risk in just assuming TWS is best.
Mods: OEM Euro Headers, RPI Scoop Daily: 2010 Tacoma Double Cab |
08-21-2012, 01:02 PM | #33 |
///M-fanatic
193
Rep 3,885
This is true.....if there's a superior blend, I'd want to spring for it. If it happens to be cheaper than TWS, then BOOYA!
I don't discount Castrol/BMW M's partnership on creating the TWS blend, but I have a tough time believing that they update the blend throughout the years to keep up-to-date with available improvements. Whereas on the other hand, these other 10w60 options/blends came out just recently, so I'd think the R&D is recent and could benefit our motors? |
08-21-2012, 07:45 PM | #34 | |
298
Rep 4,697
Especially relavent post: http://www.m3forum.net/m3forum/showp...40&postcount=2
08-21-2012, 08:34 PM | #35 |
703
Rep 7,850
Newer specs and upgraded formulas--"improvements"--are not always improvements. Example: as oil specs have changed, the amount of zinc and phosphorus have been reduced due to their impact on the cats, and due to the EPA requirements on cat lifespan. (These are important anti-wear additives that may be of concern for an engine that uses solid lifters like the S54.)
As the levels of anti-wear metals have been reduced, engines have gone the route of hydraulic, not solid, lifter design due to wear concerns. (The S54 uses solid, not hydraulic, lifters.) Other changes have been made as well, but the point is that engines have been designed to account for these "improved" oil specs. The S65 is a high-revving engine like the S54, but piston speed is lower than that of the S54, and of course the S65 uses hydraulic lifters. They share high-revving characteristics, but I would not conclude that they have the same lubrication needs. My point is that an oil that was originally designed for one type of engine may not have "improved" relative to that older engine when reformulated or modified to meet the needs of newer cars and emission regulations. Is that the case here? I do not know. However, it's something I'm reading more about, and it may be something others want to consider as well. |
08-21-2012, 08:44 PM | #36 |
Rep 688
heck I can furnish you with detailed documentation tha make Royal Purple shound like the greatest oil ever made, strange like the Castrol part above, the Royal Purple info was furnished by,.......... come on ........ wait for it.......... ROYAL PURPLE!
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor |
08-21-2012, 09:17 PM | #37 |
298
Rep 4,697
IIRC, the S65 uses a hybrid solid/hydraulic lifter?
08-21-2012, 09:21 PM | #38 |
Bad Lieutenant
232
Rep 3,517
Agree, spherical bucket type is what I remember reading back in '08
08-23-2012, 07:26 AM | #39 | |
Save the Manuals
1714
Rep 2,937
Wow! I do recall doing a numbers comparo some time ago between RL and TWS. As I recall and seen here again the RL numbers look really good!
2023 G80 6MT, CCBs
08-23-2012, 07:29 AM | #40 | |
Save the Manuals
1714
Rep 2,937
You mean cylindrical or bucket type? Is it similar to what's in the M54?
2023 G80 6MT, CCBs
08-23-2012, 10:54 AM | #41 | |
Bad Lieutenant
232
Rep 3,517
You mean cylindrical or bucket type? Is it similar to what's in the M54?[/QUOTE] Let me hunt the article, I believe they were bucket. m3forum.net quoted this from a tech article: 'Hydraulic BucketTappet The weight-optimized valves with a 5 mm shaft diameter and the spherical bucket tappets with hydraulic valve clearance adjustment are also used. These bucket tappets with a cylindrical camshaft contact surface and rotational lock allow a high level of convexity. This results in effective valve lift characteristics with the smallest possible tappet diameter and hence tappet mass (ideal for high engine speeds).'
