      09-27-2017, 04:25 AM   #1
Ponta
Ponta's Avatar
17
Drives: Z4 3.0si roadster
2007 AUX input
Hello, I would like to retrofit this in my 2006 3.0si, pictures below.
I need:
1. 2007 cover with hole for AUX-IN socket (under the A/C panel unit)#51459128397
2. AUX-IN socket #84 109237655
3. the wire #???
Can you help me finding proper OEM number for the wire?
EDIT: Can this be #61129172021?
      09-27-2017, 10:34 AM   #2
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
65120153502 "Retrofit aux harness" possibly this wire
EDIT thats not the correct connector
      09-27-2017, 10:38 AM   #3
Spaceman Spiff
Drives: R8, 996 C2, Z4MR (sold)
Instructions: https://www.bavauto.com/media/import...ges/ins314.pdf
TRiCC264.50
      09-27-2017, 02:01 PM   #4
Ponta
Ponta's Avatar
17
Ok, thanks. I have done some research and it seems to me that the wire 61129172021 would be better, it is cheaper than 84110302893 part with socket (we pay extra for socket, which is trash after all) and I do not need other parts showed in this manual:
http://www.zroadster.com/forum/index...eitung.108562/
One side you just put into AUX-IN socket and second one with 3 pins you dismount and insert behind the radio IF the space is occupied, which IS in my case because of CD changer.
      09-27-2017, 03:17 PM   #5
Spaceman Spiff
Makes sense if you already have the AUX socket part. Just seems a bit over engineered, since the other cable has no socket involved, just a wire attached to a 3.5mm female plug.
      11-07-2017, 06:28 PM   #6
apexhittinbull
Drives: E85 M
I put a Aux line on my 06 M with ebay one at $9.
Put it in the stock location with a drill.
You do not need it to say "aux-in" when it is not visible?
