04-05-2012, 09:34 PM | #311 |
6 of Diamonds (ret)
82
Rep 566
Mounting the Mstache
Of those that drilled, how did you determine where to drill?
Pull bumper off the car and set it on the the Mstache or put the Mstache in place with tape and guess? Thanks in Advance
2007 Z4Si(gone)
Couple E30 Verts (DD) 2003 330i 2011 E93 335is - current fav |
04-05-2012, 11:22 PM | #312 |
Rep 1,031
Placed it up to bumper and had it rest on wooden blocks and did the best i could to estimate where to drill. Make the hole a little bigger, more like a slot to help with aligning it. Dont make it wider than the bolt washer though. Then double sided tap the bottomand done.
04-06-2012, 08:07 AM | #315 |
Rep 446
Drives: 2013 335is
Yep, it's a M kinda thing.
Regards
2013 335is E93 2018 X5 35d BMWCCA / ZSCCA Member |
04-09-2012, 01:19 PM | #316 |
Rep 361
I've started the next batch. Please let me know if you're interested in purchasing one so you can reserve a spot.
Thanks 1. nesrevival |
04-09-2012, 02:01 PM | #317 |
Rep 782
Got mine installed yesterday ! Really compliments the look, but for the life of me , i can't understand how some folks with low cars can use this. My car is OEM height and the lip is pretty low. Will add some pics tonight
2011 30i
[SIGPIC]/SIGPIC] |
04-09-2012, 03:53 PM | #318 |
Rep 507
Hi Steve,
I'm in Canada, how much ALL IN (shipped) will it be to get in on this? You're still selling for $120 correct? Thanks!
SOLD: 2008 M Coupe
04-09-2012, 04:02 PM | #319 |
Rep 361
04-09-2012, 05:15 PM | #320 |
Rep 446
Drives: 2013 335is
Mine and Bruce's arrived today, they look great.
Thanks
04-09-2012, 06:58 PM | #321 |
Rep 32
Hi Steve,
How thick is the Mstach under the fangs? I am just trying to get a guess for how much clearance space it takes. You mentioned earlier in the thread there may be a Mstache 2 that would be a different design in the future - would that be thinner top to bottom or thicker? |
04-10-2012, 09:54 AM | #322 |
Rep 782
Ok, finally got around to taking some pics, not the best as they are from a phone, but the day was clear... Love the look
Like I said, I love the look, but I do have to be a little more careful now that I was before. It looks like It should've from the BMW factory Great doing business with you Steve!
2011 30i
[SIGPIC]/SIGPIC] Last edited by ricanbandit; 04-10-2012 at 10:16 AM.. |
04-10-2012, 05:23 PM | #323 | ||
Rep 361
Mstache 2 will have the same thickness but will extend less further out and the middle portion between the fangs will be raised upwards. Thanks for asking. I'm happy you like it Quote:
04-18-2012, 12:08 PM | #325 |
Rep 782
Well, the unthinkable happened. I guess when I used the 3m tape, it was too cold and did not set. because of this middle portion on mine kinda drooped and got serious road rash.
I think it is salvageable and that by using some sand paper I should be able to get it smooth again and then spray paint it. This time I will be a little more careful in the installation. Sad day this Sunday Here are the pics, please don't try this at home kids. Sorry for the shitty picture quality
2011 30i
[SIGPIC]/SIGPIC] |
04-18-2012, 12:52 PM | #326 |
Rep 392
Steve, Can you remove me from the list?
I didn't know there were no holes on spoiler thx.
2016 MK7 GTI PP LP DCC
2015 Macan Turbo Ordered!!! http://www.porsche-code.com/PF1XIUS5 ----------------------------------------------------------- Gone: 2007 Supercharged ESS VT-525 Z4MC |
04-18-2012, 01:12 PM | #327 |
Rep 782
Actually there are four holes that can be drilled to bolt on to pre existing holes on M bumpers. Where I messed up, was that it stated clearly on the 3M automotive tape that it should be done in temperatures of 65 or over and it definitely was not 65. So I don't attribute this to anything other than my stupidity.
the lip makes the car look sick! and I will try to fix and install again. if I can't i will order a new one. I like it that much. My only advice is don't do the half asses job I did.
2011 30i
[SIGPIC]/SIGPIC] |
04-18-2012, 05:57 PM | #328 |
Rep 446
Drives: 2013 335is
Man I am sorry to hear of the mishap. I still have mine sitting in the hall way of my office. Bruce went out of town on assignment so it will be either next weekend or the weekend after when he comes down when we put ours on. I will take plenty of pic's of the install and finished product.
Regards PS: The pictures look good even if from a phone.
04-19-2012, 12:26 AM | #329 |
Rep 231
I've had mine installed for a while now. Love the look. Used the MARSON RIBBED RIVET-NUT KIT to attach it to the car. Unfortunately, the idiot behind the wheel has hit not one but two curbs now! I repaired it the first time now I'm debating whether I should repair it again or just bite the bullet and buy a new one. Hopefully I have finally incorporated the extra inch into my driving envelope by now.
04-19-2012, 07:25 AM | #330 |
Rep 446
Drives: 2013 335is
^ - I know what you mean, that's the reason I put on the RPI skid plates after I got me a bumper stop. Darn thing just moved at me, there was nothing I could do!
