      03-13-2014, 08:24 PM   #1
CMH_328XI
Drives: bmw z4 mr
DSC Module
edited for new topic didn't feel like creating a new thread.
      03-14-2014, 05:19 AM   #2
Small Yellow
Track Addict
Small Yellow's Avatar
Taiwan
110
Drives: 2010 BMW M3 E92 | 2008 Z4M E86
Originally Posted by CMH_328XI View Post
thinking about replacing the oil pan gasket on the z4m, anyone who did this before, would appreciate some advice. Is it straight forward removal or is it like the e46 m3 where the sub frame needs to be removed? I was under the car today and it looks straight forward but I could be wrong.
Sorry no help here, would like to know too. There is a DIY somewhere with this guy replacing bearings but he did remove the subframe.
BMW ///M3 Coupe
Completed November 16, 2009
Received December 29,2009
      03-14-2014, 05:34 AM   #3
Shipkiller
Shipkiller's Avatar
Drives: Me
I had to drop the oil pan a couple of months ago..
Why do you want to do this? This is a LOT of work. It's not hard but a lot of work.
You have to remove or move out of the way the front subframe, so you need an engine support bar to keep the engine from falling….
      03-15-2014, 12:27 PM   #4
CMH_328XI
Drives: bmw z4 mr
anyone can help me locate the dsc abs and speed sensor units or modules.
      03-15-2014, 03:41 PM   #5
Shipkiller
Shipkiller's Avatar
Drives: Me
The ABS and DSC unit are integrated on the MY 2006+ (including ///M's) which uses the same (slightly modified software) unit as on the E90, the DSC MK60E5 vice the MK60 on the 03-05 models.
Feeding the DSC unit are the wheel sensors, the Steering Angle Sensor and the DSC sensor (lateral-acceleration sensor) which is located under the carpet under the passenger seat.
      03-17-2014, 11:03 PM   #6
CMH_328XI
Drives: bmw z4 mr
New dilemma, the dsc module is dead on my z4m. I've contacted module master to see if they rebuild or sell a new one but they unfortunately do not work or sell the 07+. My question is if the dsc modules are interchangeable on the z4? if not can someone know a reputable place that sells one for good price.
