      03-10-2014, 11:53 AM   #67
gmd2003
gmd2003's Avatar
352
Originally Posted by tikamak
Originally Posted by gmd2003 View Post
A surge tank won't help if it is injectors that are the problem. We can't make assumptions that the kit is good for track use as is , in any trim . I've proven that even in VT-1 trim it needs more oil cooling, and on high Air density days during hard track use it may run lean due to injector choice. Remember I overbuilt my car on the fuel delivery side and still had issues bc of the injectors .
George
I was thinking about fuel starvation because he has the VT1 kit.
From the injectors yes maybe . Remember I still had on track limp mode with a brake booster check valve , an upgraded oil cooler , and a high flow fuel pump with a full tank of gas . Looking back I'm not sure the 350 cc's were enough with my catless SS headers on my VT-1 setup for hard track use .
