      01-22-2014, 02:53 PM   #1
close_to_the_edge
close_to_the_edge's Avatar
Turkey
Drives: 2007 Bmw Z4 3.0 Si Coupe
sport mode?
Hi all, I have a 3.0 si coupe with automatic transmission for six months.
I didnt push the sport button yet because I dont know how to use it. I looked at its manual but there is no information enough about it.
Is there anybody to explain me about it simply?
regards
      01-22-2014, 03:21 PM   #2
bjbstewart
bjbstewart's Avatar
Drives: 2007 BMW Z4MC
do NOT push that button. It is for professionals only. ;-)
[SIGPIC][/SIGPIC]
      01-22-2014, 03:25 PM   #3
close_to_the_edge
Turkey
dont worry I'm professional generally drive my car high speed, but want more than that
      01-22-2014, 03:33 PM   #4
seank
enthusiast
seank's Avatar
48
A search for "sport mode" will answer your question that has been covered many times. New info we can help with.
Btw, most don't use it.
      01-22-2014, 03:51 PM   #5
close_to_the_edge
Turkey
Yes, I get the topic with enmough information. Thanks.
      01-22-2014, 05:44 PM   #6
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
///M guys don't use sport mode. You have a 3.0si so it is different. I had a 3.0 before and use the sport mode every time I start the car. It tighten the electric steering and have different shift point for auto tranny. Accelerator is remap for better response. I believe that's all it do.
      01-22-2014, 05:51 PM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
Originally Posted by RobMCoupe View Post
///M guys don't use sport mode. ...
I use sport mode 100% of the time.
My previous ride of 22 years had a "binary throttle", so it's what I'm used to.
But then, I'm just driving to work and back.
As fullerra states below, it's probably too nonlinear for precision driving.
      01-22-2014, 05:54 PM   #8
RobMCoupe
RobMCoupe's Avatar
60
You are one of the rear ///M drivers.
      01-22-2014, 06:15 PM   #9
fullerra
fullerra's Avatar
14
Drives: 08 Z4M Coupe
test test  [0.00]
2008 BMW Z4MC  [0.00]
Initially I used it to help with rev matching for heel/toe downshifts on the track, but that benefit was FAR outweighed by the inability to modulate the yaw angle mid-corner
      01-23-2014, 12:59 PM   #10
close_to_the_edge
Turkey
should I push the button before start my car?
      01-23-2014, 01:06 PM   #11
close_to_the_edge
Turkey
dear fullera, sorry, I didnt understand your words, can you explain it with simple words please?
actually its hard to me to find out meaning of special terms here.
      01-23-2014, 01:08 PM   #12
close_to_the_edge
Turkey
by the way you, M drivers, genearlly use manual shift I know, I think you are talking about manual shift but my car is automatic, is it make any difference?
      01-23-2014, 01:09 PM   #13
close_to_the_edge
Turkey
One more thing there are only one m coupe in Turkey, others are only 3.0 si.
      01-23-2014, 02:05 PM   #14
RobMCoupe
RobMCoupe's Avatar
60
After car is started.
      01-23-2014, 02:16 PM   #15
close_to_the_edge
Turkey
dear stickMon, what do you mean precision driving?
I have only one car and I drive it all time, going to work and other leisure but not in the long way.
      01-23-2014, 02:25 PM   #16
Westersund
Westersund's Avatar
Sweden
496
Drives: BMW
I hate sport mode in my M.
      01-23-2014, 03:45 PM   #17
StickMon
StickMon's Avatar
Drives: 2006 MR
fullerra's comments, that don't translate easily, refer to skilled driving on the track.
The bottom line is that sport mode is a matter of preference.
Whatever suits your use and driving style.
As for specifically what it does on a non ///M, I'm not sure.
Hopefully you found that in another thread.
Probably:
1) More sensitive throttle. Not more power, just more throttle with less pedal.
2) Less input from electric power steering assist, to give you better road feel.
With an automatic, maybe:
3) Shift points moved to higher revs.
But I don't know for sure on that one.
      01-23-2014, 05:07 PM   #18
fullerra
fullerra's Avatar
14
test test  [0.00]
Sorry abt that...
If you are not driving on the track, I wouldn't worry about sport vs. non-sport mode.
In practice, it may make the commute a bit more fun (sport mode on), as it may feel as if the car has better acceleration. That being said though, if it is for commuting, your gas mileage may suffer a bit.
Sorry If I added more confusion.
      01-23-2014, 06:19 PM   #19
m5m3mc
Drives: M-B C63
Big difference. In your car I'd use it 100% of the time. In my M Coupe it makes the car undriveable in normal city conditions.
      01-23-2014, 07:25 PM   #20
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
The Sport Button on the E85/E86 Z4 does three things.
  • Changes the throttle response on all models
  • Changes the steering feel on non-M models
  • Changes the shifting on Auto/SMG models
The effects are pure personal preference. I don't use it much, I press the DSC button more often to turn the traction control down a bit (DTC)
      01-24-2014, 07:32 AM   #21
close_to_the_edge
Turkey
Sorry abt that...
thanks for your replay. I understand now.
except driving on the track?
thanks
      01-24-2014, 07:34 AM   #22
close_to_the_edge
Turkey
Dear psygnosis, my coupe is not ///M but has a ///M steering. I think sport mode on makes change my steering.
thanks
