04-28-2014, 09:27 AM | #1 |
Rep 185
Vanos Elimination
Just saw this on VACs site. http://store.vacmotorsports.com/vac-...kit-p1344.aspx
Has anybody done this before? Pros/cons? Im assuming some power loss and a possible tune but it may be worth it to never have a vanos issue again. |
04-28-2014, 10:12 AM | #2 |
Rep 68
I feel like you'll run into the usual Z4M issue which is engine management. Might have to run a standalone.
RPI scoop, Euro headers, SS PowerLoop, Epic race tune, AKG motor/trans mounts, Turner camber bolts |
04-28-2014, 01:40 PM | #3 |
Rep 222
Why?
Surely the whole point of the Vanos is that it adjusts valve opening dependent upon RPMs to give a strong torque/HP curve throughout the rev range? What am I missing? |
04-28-2014, 04:28 PM | #5 | |
1817
Rep 5,337
Not intended for what you think, OP.
04-28-2014, 04:35 PM | #6 |
Rep 987
My guess (and it is a guess) is that you would have a slight power gain but decreased MPG for normal driving.
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights |
04-29-2014, 12:45 AM | #7 |
Rep 69
If you search "VANOS delete" through E46 M3 forums you will find a lot of information on this.
Probably the only reason to do it on a S54 is to install a turbocharger and run standalone engine management. But even in that case, VANOS delete is questionable. Keep in mind that the salt and pepper of the S54 engine is the head, and VANOS is the technology which makes possible a nice torque curve over a wide range of RPM. Without VANOS, your S54 would be nothing more than a M50 with extra displacement and slightly better flowing head. |
04-29-2014, 02:09 AM | #8 |
Rep 222
In a "normal" normally aspirated engine, without Variable Valve opening technology, as the rpms increase, the time that the inlet and exhaust valves remain open gets progressively reduced, as such the engine performance is not "optimised" at all rpms and will produce a torque curve with a definite peak. The purpose of the Vanos is to variably adjust the valve opening times to compensate for the increase in rpm so that the torque/power of the engine is optimised over a much wider range of rpms, producing a torque curve which tends to plateau over a few thousand revs and with reduced loss of torque output at peak revs. Therefore, deleting the Vanos alone will not produce any power gains and will actually produce a performance loss at higher rpms
04-29-2014, 11:52 AM | #9 |
Rep 2,782
I think the question was more along the lines of, can you do the delete along with a tune in order to never have to worry about VANOS bolts or exhaust hub failures. I would gladly take a 20 hp loss to have an engine that didn't have these failures. Any more than 20 hp and I'll roll the dice
04-29-2014, 12:37 PM | #10 |
Rep 515
It's generally for big cams that are no longer compatible with vanos. Once you go with some of the more aggressive cams you can no longer mess with cam timing without making an expensive mess. Some do it on race engines as there is no need for the lowend power lost and in that scenario it is done for simplicity, reliability and ease of tuning. Also some stand alone ecus are not capable of controlling the vanos...yet another reason.
04-29-2014, 03:26 PM | #11 |
Rep 104
I had the Vanos keep or delete quandary when my Z4 M Coupe engine was being built for turbocharging. It was decided that it was not that necessary for my track car with maybe Motec or Life engine management. If it were a road car and maybe supercharged with standard ECU modified, I would have left the Vanos in place. Hopefully I have made the right decision, and also simplified the engine and got rid of some weight too! The car won't be running till next year due to the complexity of the build, so fingers crossed! LOL
04-30-2014, 08:12 AM | #12 | |
Rep 185
