      05-04-2014, 03:45 PM   #1
GammaZeta
Drives: 1
The gremlins got me...need help.
D
      05-04-2014, 04:10 PM   #2
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6337
I say 1 or 3. Bmw batteries cause funny symptomns sometimes
instagram: @ dubsesd
      05-04-2014, 04:13 PM   #3
GammaZeta
Drives: 1
The battery is an aftermarket NAPA from the previous owner, not stock.
      05-04-2014, 04:57 PM   #4
pungo
pungo's Avatar
Originally Posted by GammaZeta View Post
Today, went to get bagels, car ran perfectly. On my way home, and going up a narrow, steep and very busy mountain, my car just goes BAM! Cuts out.
Did your car actually make a "BAM" noise or did it just "cut off" or both?
What is the voltage of the battery when reading it with a volt meter?
How many bagels did you get? Maybe you exceeded the weight limit of the car
      05-04-2014, 05:09 PM   #5
GammaZeta
Drives: 1
Well, not sure if it was a bam, rather than a shock of OMG for me.
Not sure it is the battery now, everything lights up, radio, radar detector, etc., when I turn the key to on, except instrument cluster and it won't turn over...just that CLUG.
Just pulled the codes:
P1644 - fuel pump
P0344 - camshaft position sensor
P0340 - camshaft sensor
U112b - no message from instrument cluster
      05-04-2014, 05:17 PM   #6
itdnwiwbp
Drives: 330iZHP
I think he just meant that bad batteries in BMWs can cause stange issues, not necessarily OEM batteries. I've experienced some of this phenomenon. Before I knew I never would have thought the issues I had would be caused by a bad battery. I don't know what your issue is but I'd guess 1 or 3. Good luck and I hope you get it sorted quickly and easily!
      05-04-2014, 06:06 PM   #7
GammaZeta
Drives: 1
UPDATE:
Ok, went outside to try to turn it over again, and now the cluster is (intermittently) back with the EML, SES and Traction light on. Also, it no longer CLUGS but has that familiar click-click-click sound now.
Was thinking it may be something catastrophic for a while, but now maybe leaning more towards battery/alternator.
      05-04-2014, 08:18 PM   #8
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
UPDATE:
Talked to a fellow 2 weeks ago with similar issues that BMW could not diagnose. Best Indy in town determined it to be the alternator over producing...
2006 Z4MC - #LL93158
      05-04-2014, 09:36 PM   #9
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I've went through all the possible starting issues with my car, start diagnosis with this list in terms of priority
1. Starter
2. Battery
3. Camshaft Position Sensor
4. Fuel Pump
5. Alternator
I have a used alternator sitting in my garage, I thought I needed a new one, but I didn't. I also have a used camshaft position sensor, thought I needed a new one, but didn't
      05-05-2014, 07:33 AM   #10
wolfman1807
Clueless
wolfman1807's Avatar
Drives: 2003 Z4 3.0i SMG sport/premium
Check the Napa battery, I have gone through 3 different ones in my Porsche in the last year. They have gotten some bad ones, they like to drop cells at any given moment and cause all kinds of havoc!!
      05-05-2014, 08:35 AM   #11
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
Something similar happened twice to me. First time was a bad battery (the OEM one), had it replaced. A couple of years later it was a bad starter motor and the symptoms were similar to yours. Some lights etc would turn on but car wouldn't start-up, not even the familiar click-click when the battery's dead.
