03-24-2014, 02:16 PM | #1 |
Rep 420
Strut Tower questions
Hi folks. Couple of questions here - I am replacing the black strut tower ties with a triangulated one from Ultra Racing, mainly because the tabs connecting to the strut towers have sheered. I've also noticed that on one of the holes in the tower where the studs come through there is a small hairline crack (thanks LA Potholes) so I got the E46 reinforcement plates. Before I tackle all of this I figured I'd ask you all about my following concerns:
1) Both reinforcement plates are the exact same, they are mirrors of each other and some holes don't line up: - you can see from their design and the pix of the strut towers 2) On the passenger side there is a small hex bolt screwed into the top, where as this has been removed on the driver's side. Any info on what this is and why one is missing and the other is not? Driver's side Passenger's side as you can see, the extraneous holes in the plate don't line up with every hole in the Z4 strut tower but I know the strut studs do. I think I have to remove the hex bolt in question from the passenger side to make it all work. Can anyone shed some light on this all for me? |
03-24-2014, 02:40 PM | #2 |
704
Hex bolt isn't required. Most of us deleted long ago to get greater camber angle adjustments. The three main holes are all you need to match.
Good luck with repairs. Ouch! |
03-24-2014, 02:42 PM | #3 |
Rep 5,329
i have these fitted to my z4m too..... piece of mind, i aligned them by hand then Tq'd them down..... essential imo with coil overs.......evenmore so with track type coilovers and camber plates which exert more load to the centre of the tower, these combined with the strut brace should really negate any extra stress......
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 03-24-2014 at 04:03 PM.. |
03-24-2014, 02:58 PM | #4 |
Rep 11,667
+1 to 2 above.
03-24-2014, 03:52 PM | #5 |
Rep 420
03-24-2014, 04:02 PM | #6 |
Rep 5,329
yes they are indeed from the e46 i believe..... i did get an alignment done also, But you definitely need an alignment, your drivers side camber is different to the other i can tell you that much already, one of them has the camber pins in-place from factory , the other side with the cracked firewall tab clearly has more negative camber, infact with the hairline cracks your talking about on the bolt holes, AND the firewall brace location point crack I'm wondering if this side has had some sort of impact, I'm unsure if this is the light but their appears to be some deformation to the tower too at the 9-oclock position.... ... either way you need an alignment.....
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 03-24-2014 at 04:11 PM.. |
04-08-2014, 08:17 PM | #8 |
Track Addict
110
Rep 813
Drives: 2010 BMW M3 E92 | 2008 Z4M E86
I took the part number in the picture "51717036781" and looked it up on Realoem.com and it doesn't show it as a part for e46 M3, but will it work for the e86 z4m?
BMW ///M3 Coupe
Completed November 16, 2009 Received December 29,2009 |
04-22-2014, 06:48 PM | #9 |
Rookie
33
Rep 379
i recently tried removing the pins (hex bolts) to give myself more negative camber up front, but found that the shock mounts moved (actually I also heard them moving) when I was coming off a pretty steep driveway. Is this normal, or did I just fail to tighten the shock mount bolts tight enough? I put them to approx 27Nm... Thank you
2003 Z4 2.5i
2013 FR-S 1990 911 C2 1983 Wife |
04-22-2014, 09:47 PM | #10 |
Rep 2,867
27Nm doesn't sound like it's tight enough. When installing an OE strut bar, it called for 35Nm for those nuts
04-23-2014, 01:35 AM | #11 |
Rookie
33
Rep 379
XMetal, thanks for your help!
2003 Z4 2.5i
04-26-2014, 01:17 AM | #12 | |
704
I'm sure you know this, but moving the struts inboard will increase toe-out along with increasing the negative camber. If you had a stock set-up and stock toe specs (there's a range, you'd need the alignment read-out, and that's assuming nothing has changed), you're probably running around zero toe now (fine). Still not a bad idea to get it aligned if you're unsure of the settings to start with. |
04-26-2014, 03:22 AM | #13 | |
Rookie
33
Rep 379
I pulled the pins, then replaced the pins, and all I got was this stupid stain on my t-shirt.
2003 Z4 2.5i
05-01-2014, 01:31 PM | #15 |
Wagon life
39
Rep 991
I have to chime in and ask if everyone is sure these will work? I have ordered them and have them, but it doesn't look like they line up for Z4M...
EDIT: Just looking at the picture, we should *all* be able to tell that these are the wrong plates. Please look at the alignment pin location on the strut tower as well as the reinforcement places.. It's dead wrong. |
05-01-2014, 02:26 PM | #16 | |
Rep 5,329
these are for another platform, the e46 to be precise, the pin location is different on that car to our cars location, you need to centre the plate and hold it perfectly centred while you Tq down the nuts, it fits perfectly, if you want to re-use your stock pins you can mark and drill a new hole, to clarify, these fit perfectly and mirror the shape of the strut tower to perfection.... Do no try and get these to line up the your z4's camber pin to the plates camber pin otherwise it simply doesn't work.... match the centre bore to your strut tops centre bore.
05-01-2014, 02:29 PM | #17 |
Rep 5,329
the plate perfectly centred is basically invisible..
cheap insurance and must for anyone with aftermarket coil overs, especially the hard ones like clubsport ETC...
05-01-2014, 03:29 PM | #18 | |
Wagon life
39
Rep 991
05-01-2014, 03:37 PM | #19 | |
Rep 5,329
