      08-28-2023, 03:13 PM   #1
wyshyvanuk
Drives: 2008 Z4 MR
Lambda probe (11787540167)
Does anyone know if these pre-cat oxygen sensors (2008 Z4M) are "wide band"?
Would like to have an in-dash air/fuel ratio display, but I'm more than usually clueless about the procedure. If they are wide-band, it would be tempting to somehow tap into their output, without disturbing the ECU input. Any insight? Thanks, Ted.
      08-28-2023, 03:40 PM   #2
grannyknot
grannyknot's Avatar
952
Drives: 2008 Z4M coupe
I put a wide band O2 sensor in one of the vacant front of header sensor holes so I could have air/fuel ratio in the cab. S54 engine.
The ECU and tune are so reliable that I stopped looking at it, when you gun it the mixture is richer so the ratio goes to 11-12 then back up to 14.7 where it almost always sits, let off the gas pedal and it leans out a bit, 16-17 then back to 14.7
I finally removed it.
2008 E86 M coupe
      08-28-2023, 05:07 PM   #3
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
They are 6-wire Bosch wideband sensors. You won’t be able to tap into any of the wires and get useful data due to the way wideband sensors work. Wideband sensors require a controller to output anything meaningful.
You could read lambda over K-Line if you know what to look for and have the tools. It’s better to have a standalone sensor and controller such as an Innovate LC-2. Calculated AFR can be displayed with a P3Cars digital vent gauge. Or, you could get an Innovate LM-2 and mount the display in the cabin. Just don’t leave the sensors installed in the exhaust but electrically unpowered; otherwise, they will foul quickly.
      08-28-2023, 05:17 PM   #4
wyshyvanuk
Drives: 2008 Z4 MR
1. Looks like both of my pre-cat holes are occupied by sensors. Are the holes on Canadian headers blocked off?
2. I was hoping for a "trust-but-verify" approach with the G-Power Supercharger. But I should probably go for a full Severn Tuning approach and call it a day. Pokey rocks!!
3. I was looking for a way to spend even more $$ on the Z4. The search continues ;~).
      08-28-2023, 05:22 PM   #5
wyshyvanuk
Drives: 2008 Z4 MR
Josh, I was writing my reply when yours appeared. Thanks!!
      08-29-2023, 05:04 AM   #6
grannyknot
grannyknot's Avatar
952
I removed the front two O2 sensors because I removed the front cats.
2008 E86 M coupe
      08-29-2023, 08:16 AM   #7
wyshyvanuk
Drives: 2008 Z4 MR
Understand. Thanks, granny knot!!
