10-29-2010, 09:50 AM | #45 |
Rep 632
Hey, O-cha
On the Z4, you said it would be a harder job because of clearance, can it be done though with out lifting the motor? My hunch is yes - if so, what is the critical step, if there is one, to doing it within the confined space?
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
10-29-2010, 09:58 AM | #46 | |
Rep 4,726
It is VERY close though and I'm not sure if it can actually be done when I took a second look. It boils down to with the vanos unit out as far as it can go, will you have access to the nuts of the threaded shaft and be able to move the cam to the right position (they don't move very freely)
10-29-2010, 10:13 AM | #47 | |
Rep 632
And then what is it that makes rotating the cams difficult - just the tension or friction present with the thing still as compared to when it's running? That must be why the VANOS unit has such high pressures in it... As much as I'd like to try something like this on my own, I'm still being realistic and am not sure I'd get it dead on correct. I'm up for a challenge, and I'm always trying to learn new things mechanically to increase my skill and this sort of job is about where I am with technically challenging work. I think I fully understand the issues and what special tools are needed (or unnecessary) and I'm pretty meticulous about things. But still, uncertain.....
10-29-2010, 11:29 AM | #48 | |
Rep 4,726
The tools you would need are like $800 FYI.
03-09-2012, 11:33 AM | #49 |
Rep 266
I concur with what O-cha said. Z4M has a crossbar in front of the engine which makes VANOS removal impossible without the expensive special tools. You'd need BMW special tools to get the VANOS "pistons" to retract for removal and extend for installation. I spent $900 on those tools because I track my car and want to be able to check my exhaust hub and cam bolts when I do valve adjustment.
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual 2006 BMW 330i 6spd manual - gone |
04-30-2014, 09:49 PM | #50 | |
Rookie
33
Rep 379
2003 Z4 2.5i
2013 FR-S 1990 911 C2 1983 Wife |
