12-02-2017, 03:39 PM | #23 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
https://www.ecstuning.com/b-genuine-...n/83300495528/ Check out this thread for how short it should be if you're cutting yours. http://www.zpost.com/forums/showthread.php?t=1112938 Good links and pics here, as well. The M3 DIY has lots of photos and step by steps. http://www.zpost.com/forums/showthread.php?t=1048461 Salty
apexhittinbull17.50 |
12-02-2017, 03:47 PM | #24 |
dances with roads
4737
Rep 4,099
Salty you need to change your avatar to a butt sticking out from under the hood!
Great info. I'm planning on doing the VANOS thing over the 'quiet time' this winter. Thanks for pulling so much information together in one place. |
SaltyNC369.50 |
12-02-2017, 04:30 PM | #25 | |
Rep 453
Drives: 2007 Z4M Coupe
https://docs.google.com/spreadsheets...0l5-6XtNhUkJsI |
12-02-2017, 08:21 PM | #26 | |
Rep 27
I had it cut at the local muffler shop for $10. |
12-03-2017, 05:55 PM | #27 | |
Rep 870
Salty
wdb4736.50 |
12-04-2017, 06:26 PM | #28 | |
Rep 223
The cam bearing cap nut went down the timing channel somehow: But I eventually retrieved it: This was before I decided to tear the whole thing apart. |
12-05-2017, 05:30 PM | #30 | |
Rep 223
Put several layers of shop towel or clean rags in the timing chain channel, and make sure there aren't any gaps. That nut sneaked between the timing chain and the inside of the front of the timing cover to rattle its way down to the front of the sump. Sigh. |
