01-23-2012, 11:33 PM | #1 |
Rep 1,663
RSM noise
If you have top rear shock mounts (RSM) and a roadster, do you hear noise from the back?
I have some noise from the rear when twisting the car slowly (aka ramps/driveways). First theory is that the tabs that the shelf screws into on the roadster don't let the top mounts sit flush see below:
01-24-2012, 11:34 AM | #2 | |
Rep 5,328
01-24-2012, 01:17 PM | #3 |
Rep 219
Drives: 2007 BMW Z4 M Coupe
Garage List 2000 Volve S70 se [0.00]
2000 Triumph Dayton ... [0.00] 2007 Husqvarna TE250 [0.00] 2002 Ducati Monster ... [0.00] 2007 BMW [0.00] |
Is curing up the rear carpet required for installation?
I just got a set for my coupe. I know it supposed to be fairly invoked getting to the mounts (one side in particular), but I certainly hope I don't need to cut up my trunk liner. That would suck! |
01-24-2012, 01:21 PM | #4 |
Rep 219
Damn fat fingers + iPhone autocorrect... "cutting"...
01-24-2012, 03:17 PM | #5 |
Rep 5,328
actually looking at the pic in HD on my laptop i seems to me once that piece would be tighten or aligned correctly it would be well withing those notches that you high-lighted, look at the angle of the rsm..... theirs more than enough space for this to fit once the rsm is seated correctly.....
btw when i do this install i will making sure i take apart my interior very gently, im happy to take extra time to preserve the linings in this area.
01-24-2012, 05:07 PM | #6 |
Rep 1,663
I think the carpet is already in that shape, you will have to remove the foam. I would've preferred if they cut a window in it instead of yanking it out... Not sure what else to fill that spot with. Any thoughts?
As for the plate no matter how you position it it doesn't clear the tab. I think I'm going to take it out and file it down slightly until it clears it. I don't think it will compromise functionality since RE ships one that's half of it for the e46 convertible:
01-24-2012, 07:51 PM | #7 | |
Rep 100
"Q. I have a convertible. Why do I need to have modified plates? A. Because of the different method of RSM installation in a convertible, the upper plates must be modified to accommodate and protect the tower. See pictures below, for a visual explanation. Z3 models do not apply!" Also, did you torque the top nut? "Q. I just installed your RSMs and now I have a clunk from the back. What did I do wrong? A. Check torque of top nut, making sure you have enough preload. Too much is also bad, as it prematurely wears out the bushings. " |
01-26-2012, 04:32 PM | #8 |
Rep 5,328
drop RE a message and get back to us ;-) RE state the the z4m uses the normal mounts not the half moon style ones!!
01-28-2012, 06:19 PM | #9 |
Custom User Title
144
Rep 661
I had a similar noise - turns out it was the bottom coils of the coilovers rubbing together. visible scrapes on the coils. Tested with electrical table bumpers - solved the problem. Fixed long-term with flexible cable wrap around the next-to-bottom cable. And yes, the z4M uses the standard mounts.
01-28-2012, 11:18 PM | #10 |
Rep 1,663
I checked and I have some scrapes on the coils so you might have nailed it. Can you link an example of the kind of cable wrap you used?
02-04-2012, 03:04 PM | #11 |
Custom User Title
144
Rep 661
Cable wrap link as req:
sourced from radio shack: http://www.radioshack.com/product/in...lickid=prod_cs |
08-25-2014, 09:47 PM | #12 |
636
Rep 3,124
Old thread, but
I shimmed the top plates with 5/16" I.D. 3/4" O.D. washers to get them up off the tabs that the shelf screws into.
Yea, less reinforcement, but more than with the stock nuts.
08-26-2014, 01:41 PM | #13 |
Rep 5,328
i actually contacted RE like a year ago and linked them to this thread... they said this isn't an issue, Tq them down and forget, which i did and their hasn't been an issue from day one., mine sat within the tabs when Tq'd.
