08-24-2010, 07:59 PM | #1 |
Rep 376
BG Syncroshift 2
I just picked up a 2008 Z4MC and swapped out the OEM Trans fluid for this and it worked wonders to reduce shift effort. Never tried syncromax so I can't compare.
08-24-2010, 08:39 PM | #2 |
Rep 2,138
Drives: Me
I put RP Syncromax in about two weeks ago. I agree, big difference.
08-24-2010, 11:05 PM | #4 |
Bimmer Noob
30
Rep 566
15 minutes after you get the car on jack stands. Super easy, just make sure to get a short 8mm 3/8th allen socket. Its pretty tight to get to the fill plug with a standard length socket, but doable.
http://www.zpost.com/forums/showthread.php?t=79739 This guide works, just substitute the 8mm socket for the 14mm wrench. Takes 1.6 Qt (1.5 Ltr) and torque to 26ft/lbs. I went with RP Synchromax and did notice cleaner shifts. Also did the diff with RP while up on the jack stands.
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges |
08-25-2010, 07:17 AM | #5 | |
Rep 376
Mods: OEM Euro Headers, RPI Scoop Daily: 2010 Tacoma Double Cab |
08-25-2010, 03:31 PM | #6 | |
Rep 2,138
Drives: Me
Just make sure you loosen the 'Fill' plug first.. If you can't get that one off, the don't even think about the drain plug... |
08-25-2010, 05:08 PM | #7 |
Viper Driver
36
Rep 1,311
how likely is a change of transmission fluid, especially the thinner rp synchromax, going to affect transmission wear? i'd be concerned about warranty issues, since i'm under cpo for the next two years. car only has 15,200 miles right now.
also, how much transmission fluid do we need to do a full swap? apparently, i've read that i should take it in to a proper transmission shop and have them connect a pump machine that will drain all the old fluid while pumping in all the new fluid? |
08-25-2010, 06:09 PM | #8 | |
BMW Fan
11
Rep 553
08-25-2010, 09:14 PM | #9 |
Rep 376
They only way they'll know you changed it is if you tell them.
08-26-2010, 08:18 AM | #10 | |
Rep 1,546
How often do you all change yoru fluid? I've driven mine 5K since May and Inspection 2 is 5K away. Would it even be worth it to change it out before then?
08-26-2010, 09:02 AM | #11 |
Viper Driver
36
Rep 1,311
i'd wait till inspection 2, since transmission and differential fluids will be changed for sure. u could probably ask the tech to fill with an aftermarket transmission fluid of ur choice, but the stock fluid is pretty good and should be no problems. aftermarket transmission fluid can typically last through more than 20,000 miles. bmw's oem lt2 transmission fluid is supposed to go 50,000 miles or so, hence the replacement at inspection 2.
08-26-2010, 10:27 AM | #12 |
Rep 1,546
that's what i was thinking, just didn't know for sure. this is the first car i've owned from a dealer with a warranty.
08-26-2010, 06:37 PM | #13 |
Viper Driver
36
Rep 1,311
alright, ordered myself two liters of rp synchromax off amazon + free shipping. good deal. is there something i should take note of the fill and drain bolts? i understand they can be mighty easy to strip bare and then it becomes almost impossible to remove. my concern would be bolting them back on though, will they seal sufficiently?
08-26-2010, 06:59 PM | #14 |
Rep 1,143
FWIW, my mechanic's opinion was that the only downside to BMW's tranny fluid is its expense. As far as gear protection, it's supposed to be pretty top notch. He told me that the fluid he drains out of cars with 100+K miles often looks cleaner than cars with aftermarket fluids after much fewer miles.
In the end, I guess it comes down to risk. There's a theory that the fluids that improve shifter feel are actually thinner and that's the mechanism by which resistance is reduced. Whether they provide adequate long term protection of the gears is anyone's guess. If you do change fluids, I'd get a Blackstone analysis of your OE fluid after you drain it, and then get another analysis of the aftermarket fluid after a similar mileage interval. I'm personally curious to see the result. In the meantime, since I don't ever see myself getting rid of this car, I decided to go the safe route and returned the 2 bottles of RP Synchromax I had ordered from Amazon. My transmission is on the notchy side for sure (especially comparing to the ZHP, which has an identical ZF unit I believe) but it's not so bad that it's grinded or gotten in the way of some very entertaining driving. Btw, it's recommended that you get new drain cover bolts since they're supposed to be single-use. |
08-26-2010, 10:15 PM | #15 |
Bimmer Noob
30
Rep 566
Passing along the info from Ron Stygar:
Transmission plug: http://www.bimmerfest.com/forums/sho...04&postcount=1 Differential plug: http://bimmerfest.com/forums/showpos...33&postcount=1 The plugs are not reusable, as they have crush washers on them. Ordered mine through Tischer.
08-26-2010, 11:17 PM | #16 |
Viper Driver
36
Rep 1,311
thanks for the links to the relevant part number. i will wait and see regarding the actual fill and drain plugs themselves and if they're fully sealable and reusable again with new crush washers. seems like a few zposters have swapped out their tranny fluids without replacing these bolts, and have not had any leaks to speak of.
08-27-2010, 07:20 AM | #17 |
Bimmer Noob
30
Rep 566
I just replaced the drain plug and re-used the fill plug without any issues, but that was simply because I didn't think to order two..
The part is cheap, I will order both the drain and fill plugs for next time.
08-28-2010, 12:01 PM | #19 |
BMW Fan
11
Rep 553
Actually the plugs have 0 rings, not crush washers, and I think as much as anything they should be replaced because the allen socket is very easy to strip out if you are using cheap tools. Cheap meaning not Snap On or equivalent.
08-28-2010, 01:45 PM | #20 |
Rep 2,138
Drives: Me
I think the O-Ring plugs are for older cars. Not sure.
My 08 has crush washers, and the new ones I ordered were also crush washer. +10 for the cheap tools comment. |
08-29-2010, 04:33 PM | #21 |
Viper Driver
36
Rep 1,311
going to take extra precaution regarding the use of proper tools. i've read about inadvertently stripping the bolts and the huge pain to have them removed thereafter!
08-30-2010, 06:44 AM | #22 | |
Rep 632
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
