      12-09-2020, 06:03 PM   #1
TitaniumZ4
Drives: BMW Z4
Light Control Module VIN Coding E85 3.0 2003
Just purchased a 2003 Z4 3.0. The drivers side headlight and taillight would not work (intermittently). After checking the bulbs, wiring on the car, and checking online, the best guess was replacing the light control module. Purchased a used one with matching serial numbers and it fixed the problem. Unfortunately, I have an airbag error now. The error is for mismatch of VIN numbers for several (not all) of the airbags. Can the LCM be recoded? Has anyone dealt with this problem before? Thanks!
      04-08-2021, 08:46 AM   #2
Dynamics99
Drives: 2011 E92 & E90 335i 6MT MSport
Hi,
Yes the LCM can be coded to match the vin. Use PaSoft to code your new LCM. If you are not familiar with PaSoft there is an install guide. You need a specific cable( search on eBay BMW Scanner 1.4). Once you have everything set up you can scan the LCM and code from the IKE I think.
